  4. DTR 2005 ypvs
DTR 2005 ypvs
18 Posts 3 Posters 3.3k Views 1 Watching
    Yeah, put them as it shows in the picture.
    O 1 Reply Last reply
      Oisin
      @Calum Ok thanks very much
        Oisin
        Anyone have any info on how to pin the power valve. I'm trying to get good low end power and decent high end power. What is the best position to pin it in any suggestions. All help much appreciated
          Wha?
          Pinning the powervalve won't achieve that.
          Fitting the powervalve correctly will.
          Align the powervalve so that in it's open position, it's flush with the exhaust port.
          Do this by first removing the exhaust.
          Slacken both cable pulleys so that the motor can operate freely without damage to the motor.
          Turn the ignition on and off. Switch the ignition on and wait for the valve to complete half of the operation before switching the ignition off. This is the position the motor will be in when the powervalve is fully opened. Attach the cables and adjust the cables appropriately, locking it off with the locking nut.
          Then switch the ignition on and off. Confirming that the valve operates freely and opens flush with the exhaust port.
            Wha?
            Oisin
            @Calum I have no battery hooked up so I'm just going pin again like it already was with the 2 holes aligned up. But I'm wondering if I can pin it in a different position to give me more power in the low end? I just want to stick it in a position and leave it. Do u get me?
            • O Oisin
              @Oisin Leave it pinned open, any other position will just be detrimental to performance.
              Why aren't you running a battery? The servo does work without a battery, I've just felt it's been glitchy.
              You don't need a battery to set the valve up, it's fairly trivial to set up, you just need it to do a power cycle into a known state I.E. fully open or fully close.
                Oisin
                @Calum Ok thanks very much. And how do I check if the valve is set fully open or fully closed
                  By aligning the powervalve so that it's flush with the exhaust port.
                    Oisin
                    @Calum so is it fully open in that position
                    • T
                      T
                      theportingmaster
                      HI @Oisin , not running a battery for the powervalve, a lot of years ago we just
                      fitted a pedal bike brake lever on the handlebars with some brake cables to the powervalve. That way we could adjust it easily for more top or bottom end with
                      no electics.
                      • T theportingmaster
                        no electics.
                        @theportingmaster Haha! Brilliant.
                        Any chance of getting a video of that
