  3. DTRE
  4. DT 125R not starting
20 Posts 4 Posters 4.7k Views
    Well it sounds like a fueling issue.
    O 1 Reply Last reply
      Oisin
      @Calum Would u have any ideas where I would go from here
      markus.wM 2 Replies Last reply
        Yes, check the fueling.
        • O Oisin
          @Oisin is it possible at all that when you replaced said fuel pipe it was connected back up incorrectly/ wrong place/wrong way around? Just a thought.
          • O Oisin
            @Oisin maybe check said fuel pipe is actually allowing fuel to pass through. I presume it's a new pipe but stranger things have happened.
              @markus-w I had this when I replaced it with a silicone host, it kinked and stopped fuel from flowing.
              Use properly braided and rated fuel hose. Is my advice.
                @Calum yes I agree. That's good advice. Some parts it doesn't matter so much but there's certain things you just can't skimp on.
                  Oisin
                  @markus-w got it going it was the fuel line thanks very much
                  • O Oisin
                    @Oisin happy days, you're most welcome. Can I ask what was wrong with the fuel line?
                      Oisin
                      @markus-w It appeared to be kinked under the fuel tank and so I couldn't see it. I also have the tank a good clean out which helped a lot I think
