  3. Suspension
  4. A Fairly Complete List of 41mm Forks - These Will Fit Directly into DTR and DTRE/X Yokes :P
15 Posts 6 Posters 10.1k Views 3 Watching
    I doubt you will find USDs to fit the yokes.
    @Calum nah you might be able to find the right width but they’d be so short
      @declan What like Pitbike USD's 🤣
        @Calum yep 😂
        • Stevie WonderS
          Stevie WonderS
          Stevie Wonder
          Might just have to buy some and send it, give the bike the Raleigh chopper look 😂
          Currently during to decide on a half decent set of USD that are capable of giving me somewhere to put the ignition barrel and not give me to many problems running a supermoto set up as well as YZ front wheels
            @dtStevie98 Well, I use WR250F forks, same as the 400, and I run SM wheels.
              Stevie WonderS
              Stevie WonderS
              Stevie Wonder
              @Calum any issues putting the stock 18-21 setup back on with those forks?
                I wouldn't know, I never used stock wheels with this setup.
                  @dtStevie98 The front brake caliper may need a custom bracket manufactured, plus the disc sizes for the old DTR disc pattern is very limited. You would be far better off buying a complete front end off another bike and then you will only have to have a bearing cup made up, to fit them to the DTR frame. That scenario would give you a ton more options and way more flexibility too. 😉
                    Stevie WonderS
                    Stevie WonderS
                    Stevie Wonder
                    @NINJA thank you, I think that’s a better option. I was thinking last night and I prefer this option it just gives me a lot more flexibility as you’ve said but also give me a lot more flexibility in terms of what forks I run. I was trying to avoid changing the braking setup however considering the amount I complain about the brakes, I’ll thank myself later. I’m more just looking to have the option to throw WR125X wheels on when I want with as little stress as possible.
                      @dtStevie98 See these threads bud, they will give you some ideas. If you can get hold of the full Aprilia MX 125 front end it will save you a lot of hassle, if not any other bike like a KTM/Yammy/Honda etc can be made to fit;
                      https://dt125r.co.uk/topic/1020/dtdr-build
                      And @Calum did a through guide on bearing cups here;
                      https://dt125r.co.uk/topic/17/usd-conversion-bearing-cup-method
