  4. cut manifold
cut manifold
6 Posts 2 Posters 755 Views
  • declanD Offline
    hey guys im having an issue with my dt where it will only rev to 7k im thinking its an airleak since my idle was getting leaner and leaner my inlet manifiold is basically one big cut i could use the manifold off my spare engine but the rubber guide for the mixture has been cut will this drastically affect anything?
      Shouldn't do. RS 125 doesn't have that guide so must be surplus to requirements =)
      declanD 2 Replies Last reply
        @Calum thanks ill switch it over then
          @Calum do you think it would be worth putting a 240 jet in it from my 210 i dont know if there is an issue up top but it cant hurt right? since a lot of our dts already have the 240
            So you're saying you can jet the bike better than Mr Yamaha?
            If it needs doing then do it. If it doesn't then I doubt there is much to be gained.
              @Calum okay thanks bud
