  4. Dies out when I give gas
10 Posts 3 Posters 706 Views
  • Haako SmithH Offline
    Haako Smith
    My bike recently died out when I gave full throttle. I have cleaned the carb, but it still doesn’t help. Any ideas what it could be?
    • Haako SmithH Haako Smith
      @Haako-Smith virtually anything browse some threads with the search function and do some tests via the Haynes manual
        Haako Smith
        When I let go off the gas it sometimes revs up really high. False air maybe?
          Haako Smith
          I tried to spray some brake clean around the intake, but it didn’t make a difference
            @Haako-Smith clean carb likely a blocked jet
            Haako SmithH 1 Reply Last reply
              Haako Smith
              @declan
              Already cleaned it, everything is fine
                @declan
                @Haako-Smith maybe a leaky left crank seal or more simple stuff like bad petrol blocked petcock split fuel hose incorrect float height
                  Haako Smith
                  Hmm, could be the crankcase seal.
                  But it is on and off. Sometimes it bogs down, and sometimes it doesn’t. I took it for a little ride now, and now it was fine.
                  • S Offline
                    Water in petrol? Drain the carb bowl?
                      Haako Smith
                      Have drained the carb multiple times,
                      No water and stuff
