  3. Carburetor
  4. Choke
Choke
7 Posts 3 Posters 922 Views
  • C Offline
    C Offline
    chris
    How it dissasemble this?
    choke
    I want to change the seal ring
    • C chris
      choke
      @chris
      I don’t think you can if I remember when I stripped my carb.
      C 1 Reply Last reply
        @chris
        C Offline
        C Offline
        chris
        But spare parts are available, I bought the rubber ring from Mikuni and it wouldn't make any sense
        I could think of cutting the old ring and pushing the new one over the thread up to the position, but think that's not the right way
          Maybe the plunger comes off in a non-breakable fashion. But more likely that the part number for the O-Ring matches the part number for the plunger in the mechanism where it is cable operated not lever operated.
          • C Offline
            C Offline
            chris
            Just found it out
            The plunger has to be pulled down firmly
            Then the parts are separated
            choke dissasembled
            • C chris
              Just found it out
              choke dissasembled
              @chris
              Sweet, that’s good to know. It just pushes into the rubber?
              Can you give us a link to where you got the spare bits?...
                @chris
                C Offline
                C Offline
                chris
                yes the spring, rubber parts and piston are available at mikuni
