  4. fitting later engine cases to older engine
3 Posts 2 Posters 578 Views
  • D Offline
    D Offline
    dan28
    if i swap the old style plastic cases for the newer metal ones do i need to change the water pump an oil pump over from the old case
    the new case has them fitted already
    • D dan28
      @dan28
      I didn’t know that there was a plastic side case, but if it has the same pumps it should be ok. I’d keep my original oil pump if it’s good. Just cause it’s calibrated right.
        @dan28
        D Offline
        D Offline
        dan28
        @spookdog said in fitting later engine cases to older engine:
        @dan28
        89 cases are plastic the later cases are alloy
        The oil pumps have a different part number not sure about water pump.
