  4. Jetting Athena 170kit dtr
2 Posts 2 Posters 1.0k Views 1 Watching
  • W Offline
    W Offline
    waale2004
    wrote on last edited by waale2004
    What jetting do you recommend on a Yamaha dtr 2003 model with Athena exhaust and stock mikuni carb. And 170 Athena big bore kit
    T 1 Reply Last reply
    • W waale2004
      T Offline
      T Offline
      theportingmaster
      @waale2004 Best jetting for Athena 170 is 300 main jet on the
      Mikuni tm28 but with the powerjet blocked off. Just cut the
      rubber tube in half from the float chamber to the powerjet then block the 2 halves of the rubber tube with a couple of 5mm threaded bolts or similar.
