  3. Suspension
  4. DT125R Linkage Bearings/Bushings measurements
7 Posts 3 Posters 1.5k Views 1 Watching
  • D Offline
    D Offline
    DanielClox
    Hey guys,
    I am trying to source the bearings/bushings and seals for the swingarm linkage on my DT125R from simplybearings so I can save some money 😆
    But I am having trouble finding the measurements (I don't have the ones I took out to measure)
    The part numbers are:
    14 - 93315-32052
    15 - 9310920076
    16 - 90387-164U7
    20 - 90386-20120
    21 - 9310920076
    Does anyone know the measurements of these parts?
    For the 14 bearings, I have seen mentioned here in this forum both 22x28x20mm and 20x27x15mm
    The 16, I have seen it linked somewhere to a bushing with the measurements 16x22x66.5mm which would indicate the bearing has to have 22mm inner diameter, but, I have found a page saying the bearing is 20x27x15mm (http://www.pivotworks.com/ProductInfo.aspx?item_id=52432)
    If anyone can shed light on this would be appreciated. Thanks in advance
    • D DanielClox
      Hey guys,
      14 - 93315-32052
      15 - 9310920076
      16 - 90387-164U7
      20 - 90386-20120
      21 - 9310920076
      @DanielClox
      Have you tried contacting them and telling them what you want? As far as I know there aren’t any different variations, year to year or dtre, whatever.
      I’m sure they’ll be able to sort you out...
        @DanielClox
        D Offline
        D Offline
        DanielClox
        @SpookDog Who do you mean by "them"? You mean contact simplybearings to see if they know the dimensions by part number?
        CalumC S 2 Replies Last reply
        • D DanielClox
          @DanielClox I think @SpookDog Means Pivotworks.
          They are listing the bearing under that part number after all.
          I'd press the original one out and just measure it if it were me.
          • D DanielClox
            @DanielClox
            Sorry, ignore me. For some reason I thought it was All Balls you were looking into. They do the whole linkage kit for about £50...
            I really need to reassess my speed reading posts! 🤪
              @DanielClox
              D Offline
              D Offline
              DanielClox
              @SpookDog No problem ☺
              I don't think they do, the kit they sell only has the bearings and bushings for the swingarm, not the linkage
              • D DanielClox
                @DanielClox
                Again, sorry! I must of been having a massive brain fart! You’re right, I thought I had a link saved but it’s for a Yz for some reason 😐
                The only linkage kit I can find now is £110 ☹️
