  3. Suspension
  4. Special tool for fork disassembly
9 Posts 3 Posters 2.2k Views
  • Hybrid_Theory01H Offline
    Hybrid_Theory01
    wrote on last edited by Hybrid_Theory01
    Hello guys, I need to replace the fork seals on my DT 125 R and it requires a special tool to disassemble the bottom bolt on the fork, in this video I found, it looks like a square, any additional information on that? thanks
      @Hybrid_Theory01
      It’s a hexagon that happens to be the same size as the swing arm bolt, 22mm I think. Someone on this site made a tool from one IORC
      You could make a tool by welding a 22mm nut on either end of a threaded bar...
      Or you could do what I did 🙂 Get a good, strong, hardwood broom handle and whittle a ‘squared off’ point onto the end. It doesn’t have to be a sharp pointed end. Just has to fit inside. Give it a whack with a lump hammer to set it and hold with a set of gorilla/vice grips. Or Stillsons, whatever, while you undo the fork bottom Allen bolts...
      Just make sure the bottom Allen bolts are lubricated, free and turning first...
        Hybrid_Theory01
        oh, thank you, I will do a bit more research and maybe make me the tool
          @Hybrid_Theory01
          The brush/rake handle idea was in the Haynes manual I think. It does work as long as the handle doesn’t shiver into splinters!...
          Search the site for ‘fork tool’ maybe?...
            @Hybrid_Theory01
            The damper rod is 27mm where the special tool fits (same size as the rear wheel spindle hex). You can make one by cutting the threaded end off a rear wheel spindle (try and find one with a knackered thread) and grinding an 18mm hex onto the shank so it fits into a socket. Then just loads of 1/2" drive extension bars.
            As you've got the grinder out, make the 18mm hex long enough to fit into a deep socket to get maximum purchase.
            Torque setting for the bottom bolt on reassembly is 62Nm with blue Loctite and a new copper washer and this tool was strong enough!
              Hybrid_Theory01
              @HOTSHOT-III that’s a great idea, I will try to make myself a tool like yours! Thanks for the tip
                @Hybrid_Theory01
                Hybrid_Theory01
                @SpookDog i think the idea of making the tool is great, since I work at a car shop I will be able to make the tool easily, thanks for the tip, the Haynes manual has a ton of good information!
                  @Hybrid_Theory01
                  Lucky bugger having a workshop!..
                  27mm nut welded to a long steel bar with a ‘T’ bar at the end. You could sell them!...
                    @Hybrid_Theory01
                    Hybrid_Theory01
                    @SpookDog I made myself a little tool I will send a picture when I use it, it’s simple and uses the same logic
