  4. dt 125x crankcase seal what way
6 Posts 3 Posters 1.2k Views
  • W Offline
    W Offline
    Waggstar
    Hi does anyone know the way the right-hand crankcase seal goes on a dt 125x,
    is it with the spring to the inside of the crank or the outside.
    • W Waggstar
      HOTSHOT IIIH Online
      HOTSHOT IIIH Online
      @Waggstar Is it a genuine seal? If so it should have "outside" written on it between the lip and the outer edge
      W 1 Reply Last reply
        W Offline
        W Offline
        Waggstar
        No, its not a genuine one nothing on the seal saying, so should i have the spring side facing in.
        • W Waggstar
          HOTSHOT IIIH Online
          HOTSHOT IIIH Online
          @Waggstar Just fished out a new genuine one and it actually has a garter spring on both seal lips!
          The one marked "outside" has a thinner seal lip than the other side so I'd say orient the seal lip with more surface area towards the crankshaft.
          Also had a look at one out of a Yambits seal kit which also has a garter spring on both lips but I can't see any difference between them so if it was me I think I'd be installing it with the writing on the outside (i.e facing away from the crankshaft).
            W Offline
            W Offline
            Waggstar
            Thats just what il do cheers for the info, Hotshot
            • W Waggstar
              Just make sure that it’s in there nice and squarely. Also that the ‘insert’ has a good clean finish with no bad grooves or crud buildup on it 🙂
              Did you split and rebuild the cases or just replace the seals? (both)...
              Just use a proper clutch holder to tighten (or loosen) the clutch centre nut, don’t stick a screwdriver in the outer basket ‘fingers’! The alloy snaps so easy and without warning!...
