Battery eliminator???
So if i was to buy one of these to remove the battery and shave a bit more weight off the dt would it be a probelem for the power valve? Usually when I turn on the ignition it does a power valve cleaning cycle before I've kick started the bike. What would happen if the CDi/power valve suddenly got the power as the engine started? eBay: http://pages.ebay.com/link/?nav=item.view&id=272360096529&alt=web
I ran this Capacitor for a long time using the standard CDI and had no problems with the YPVS servo motor. Yes without charge it won't activate the cleaning cycle from Ignition.
These capacitors don't hold much charge, and I encountered program/eratic sparking, Miss firing issues using a Programmable CDI without a constant 12V feed.
@Darty so are you saying standard cdi(which i have) it should be fine/ Programmable CDi it could be an issue?
