  3. Choppy power band
Choppy power band
36 Posts 6 Posters 16.7k Views
  • MadGyverM
    MadGyverM
    @Hark_Ptooie
    Is the carb the original one.240 main jet should come on an earlier DTR model.
    • Hark_PtooieH Hark_Ptooie
      I would add that despite writing about the derestricting, I consider this more of a tuning issue. Some component does not do what it is supposed to. I wish to troubleshoot, but I am at a loss for what it could be.
      @Hark_Ptooie
      240 were on 98-03 (off the top of my head!) it should have a 25 pilot jet (not .225) and the needle should be 1 clip up from the bottom…
      Does it have a yellow plastic ring that fits under the slide spring? Also a plastic tube that fits into the pilot jet tube and around the main jet?…
      It does sound like a jet/tuning issue. A previous owner leaving their’mark’ on it! 😛 …
      Hark_PtooieH 1 Reply Last reply
        You shouldn't need to mess with the carb for the expansion chamber, despite how counter intuitive that may be.
        I'm likely to say, based off the description, that this sounds like a health issue.
        Are you sure that the powervalve is operating as intended, it's not coked up and in need of a good clean.
        The airbox is flowing freely, filter not clogged up, oil is lubing correctly, not overly smokey. The spark plug is in good condition, I recommend using an Iridium plug.
        The general health of the engine is good?
          He said it used to choke out a bit earlier before he changed the pipe. It was an existing issue from before. The carbs obviously not set right if it has a 240 main jet with the needle set in the middle…
          Just need to suss out which iteration of carb it is and set it back to standard…
            @Hark_Ptooie
            Hark_PtooieH
            Hark_PtooieH
            Hark_Ptooie
            @SpookDog said in Choppy power band:
            Yep, and yep.
            Airbox is clean, new filter, oil seems right (some blue smoke on choke start, disappears when running, my jacket smells of 2-stroke when I stop...). The intake manifold rubber thingy is pristine and uncut. *) I can't really turn out the air screw more than 1½ rotations, because then it gets stuck and the groove is damaged.
            Before the new expansion chamber, there was no noticeable difference between the old and new spark plug.
            However, now when it's mentioned - it did do that sputtering before the expansion chamber swap as well. I just assumed that it was part of the restricting. Since it occurred right before the nonexistant upper power band.
            When I looked at the powervalve position and felt inside the exhaust port, it was rough and sooty. So I suspect the YPVS.
              • Some apparently attempt to tune these bikes by cutting off the rubber nose thingy that goes into the reed valve. I actually spent my weekend doing a CFD analysis on this and found out that it is useless. Removing that square funnel drops the mass airflow with about 2%. Trimming its edges though to make it slightly more oval can increase the airflow with about 1%. Tops. Then again, I am a dilettant at this.
              Yep, and yep.
              @Hark_Ptooie
              Check for the right pilot jet: 25 (it makes a difference if it’s wrong, it did to mine)
              Put the needle clip on the second lowest groove.
              1 & 1/4 turns out for airscrew (you should fix it so you can remove it completely. The o-ring may be perished inside)
              These are the settings for that carb…
              Make sure both jets are totally clear. You should see daylight through both 🙂 …
              • Hark_PtooieH
                Hark_PtooieH
                Hark_Ptooie
                Will do. We have an ultrasound bath at work that I will stuff all the parts in.
                Perhaps even get a Mikuni TM28 renovation kit from eBay and fix it up well.
                Thanks!
                  Hello
                  I recently bought my third DT, a DE03 from 2003, and set about to derestrict it.
                  Pulled out the gizmo in the speedometer and wrapped it in tape, then installed an Athena expansion chamber. Kept the old muffler because I don't want it to be unduly loud. I intend to register it with its original power because I am of age, having owned various bikes, and don't want problems with the wossname yearly vehicle testing they do here in Sweden.
                  Anyway - the new expansion chamber did indeed make it rev out with all its intended power, as it feels. The problem I have is a sputtering and hesitation about round 7000 rpm. Not exactly sure when, the tachometer cable is worn out and I await a replacement, but it is right north of where it used to just choke out before I swapped exhaust.
                  I have scoured the web for clues about carburetor jetting, but they all talk about 1/4 throttle and such. This is not related to the throttle position - it is at a certain rev band that it sputters and chops, before proceeding to zing out to the end. Otherwise it is responsive, what little torque it has below 6000 rpm or so is delivered as it should (I can tell from my previous DTs). The main jet is a 240, the needle is lifted one step from the center, it was like that when I got it and I have not changed it. The pilot screw head is a bit damaged so someone has fiddled with it before.
                  The YPVS seems to work as intended, and its starting position is flush with the exhaust orifice, the notch on the cable thing right over the hole. New Denso IW27 iridium spark plug.
                  So - anyone got any lead on why it sputters and chops right before the top end power band? Lean/rich? Advance the YPVS? Change to copper spark plug?
                  @Hark_Ptooie hi bud, first you need to establish exactly which model you have. The 'gizmo' in the speedo you mention is the reed switch which was on the 4BK model, 99-03. Yet the DE03 you claim to have (03-07) didn't have the reed switch but had the green/black wire to earth the CDI. Has the engine been changed? Does yours have electric start? Do you know if it's a DT125R/DT125RE/DT125X/SM?
                  • Hark_PtooieH
                    Hark_PtooieH
                    Hark_Ptooie
                    It is a 2003 DTR, DE03 which is "mid 99 to 03 models" from what I have read. No electric start, and it has a reed switch - no green/black wire to ground, that came with the 2004 facelift and the RE and X. No?
                    I find different such specs on different sites, so I suspect it could depend on the market. I am in Sweden, for what it's worth.
                      That's correct, the Green/Black wire is for the RE/X models. That, and the exhaust, were the only restrictions on those to make them full power. Very easy to derestrict the last generation.
                        Why does everyone call them a ‘reed’ switch? It’s that thing of hearing it from two different sources makes it right? ( or once on the web!) Like bigger jets = more power (not black plugs 😛), or are needed in DEPs?
                        It’s a read switch I found out.
                        Yes I am pedantic! 😀 …
                        markus.wM 2 Replies Last reply
                        • Hark_PtooieH
                          Hark_PtooieH
                          Hark_Ptooie
                          Because it is a reed switch.
                          https://en.wikipedia.org/wiki/Reed_switch
                          It is a sensor that detects the speedometer needle getting to a certain position. It is disabled by gently lifting it away from that spot, so it detects nothing.
                          Not to be confused with the reed valve, which is an entirely different thing. That is a cage with reeds in it. https://en.wikipedia.org/wiki/Reed_valve
                          I am assuming they called the blades "reeds" because they are similar to the blade in the mouthpiece of some instruments. https://en.wikipedia.org/wiki/Reed_(mouthpiece)
                            @Hark_Ptooie Just read through this thread again, do I understand correctly you're running an Athena expansion chamber and stock silencer? If so that could be having a negative effect as the stock expansion chamber and silencer are designed to work together on some models. Not precisely the same situation but I once fitted a DEP silencer to my '93 French import with stock expansion chamber/3NC CDI, and it immediately refused to rev beyond 9000rpm. It literally hit a brick wall and I tried it in a few different directions to eliminate the possibility of the prevailing wind that day. This was cured straight away when I refitted the stock silencer; 10,500rpm with no issues. So a Athena expansion/stock silencer combo could potentially also have an unpredictable effect as you're basically messing around with pressure waves, back pressure etc.
                            IIRC the Athena expansion chamber is the same as a Tecno (exactly the same pipe but unpainted), eventually I ran this with a DEP silencer and stock jetting on the same bike and the performance was basically identical to having a stock expansion/silencer combination. So maybe try a DEP silencer and see if that delivers any improvements. It shouldn't be much louder, just a different exhaust note mainly.
                            • Hark_PtooieH
                              Hark_PtooieH
                              Hark_Ptooie
                              Hm - you got a point. Yes, I run the stock silencer.
                              It does rev freely - exactly how far I am not sure at this moment because the tachometer wire needs replacing and I wait for the part, but it is likely beyond 9000. I am quite happy with the peak power, it is that sputtering around some 7000 or so that irks me. Could be related to the silencer, but it was there before I swapped the expansion chamber, though I thought it was because of the restricting.
                              So, before swap: pulled as well as a 2-stroke 125 cc can down low, had a notable torque increase at 4-6000, then sputtered and choked out over about 7000. Felt like 14 hp, so I figured it was how restricted DTs were.
                              Now: exactly the same, only it comes again above that sputtering region, and feels a lot like the 23 hp it should be. My old DT's had torque drops about at that region, but didn't sputter and cough.
                              I don't know the term for it in english, in swedish we say that a two-stroker "four-strokes" during some conditions. On part throttle, much more pronounced in old-time two-stroke mopeds that had no reed valves and such and were terribly tuned. Instead of BWAAAAP, it does some BABWAP BABWAP hurle cough. That is what mine momentarily does in the transition from middle-rev to top-rev.
                                @Hark_Ptooie Four-Stroking is usually down to overfueling in that region. You could try lowering the needle clip position to lean up the mixture.
                                • Hark_PtooieH
                                  Hark_PtooieH
                                  Hark_Ptooie
                                  Oho - thanks for that clue! Will do.
                                  I have noted an unusually pungent exhaust smell from my jacket after driving, and wondered if it may perchance actually run too rich.
                                    @Hark_Ptooie
                                    Check your plug bud. If it’s black and sooty then yes…
                                    • Hark_PtooieH
                                      Hark_PtooieH
                                      Hark_Ptooie
                                      Today's quiz: is this the spark plug of a rich, lean or normal mixture? It has only been in use for about 40 miles, but I drove vigorously.
                                      The shiny spot on the far side is where I touched and got the oily soot on my finger. So I'd say it is on the rich side.
                                        #21
                                        @Hark_Ptooie
                                        Looks weak to me, if anything…
                                        It would be black if it was rich, in my tentatively humble opinion (because I have made some gaffs lately)
                                          @Hark_Ptooie
                                          #22
                                          Don’t know why I didn’t notice it before, but have you put the magnetic speedometer reader (😀) switch back in its place? Or moved it completely away?
                                          I think you may still be having troubles with it. It’s right around the rpm’s you’re having trouble at…
                                          Read mrShadi’s post (deristrict Yamaha dt 125 r 1997) on his fun with deristricting!…
                                          I’m probably wrong but you never know…
                                          Or did it sputter before you deristricted it?…
