  3. Derestricting
  4. Derestrict yamaha dt 125 r 1997
66 Posts 5 Posters 29.6k Views
  • Mr ShadiM Mr Shadi
    @Mr-Shadi i moved the reed switch, cut wires and did a lot of things but when the reed is out of its slot the bike won't rev over 6k in 2nd 3rd 4th 5th and 6th gear, but when the reed is in its slot it only doesn't rev when 80km/h. I even pulled the reed out a little bit and it didnt rev over 6k. Very weird
    markus.wM Offline
    markus.wM Offline
    @Mr-Shadi you have the 4BL model, that's the later one with the reed switch but I guess you must have the restricted 3RM-10 CDI?
    Mr ShadiM 1 Reply Last reply
    • Hybrid_Theory01H Offline
      Hybrid_Theory01
      wrote on last edited by Hybrid_Theory01
      #56
      Hey guys, my CDI has 2 plugs with like 4 wires coming out and plugging into themselfs, has anyone seen this before or should I send a picture to this chat? Its at least weird but Thats how i bought the bike
        I’ll look for a 4bl (I’ve never heard of a 4BL, you sure it’s not 4DL?) wiring diagram…
        It is bl just checked
        Mr ShadiM Offline
        Mr ShadiM Offline
        Mr Shadi
        @SpookDog sorry for not being active i had stuff to do. yeah its a 4bl not a dl, if u google 4bl this bike will come up and its exactly my bike ceaed3d7-2991-45db-8806-ec0c2fdac194-image.png and the reed switch i already drew it was green/red and a blue one
          Mr ShadiM Offline
          Mr ShadiM Offline
          Mr Shadi
          @markus-w it has a restricted cdi but its weird that if i move the reed switch at all it dosent rev over 6k. and i was thinking if i cut the wires and leave the reed switch in its place without the wires, maybe it will work.
            Mr ShadiM Offline
            Mr ShadiM Offline
            Mr Shadi
            @Mr-Shadi i searched for wiring diagrams and i found one very pixelated one that showed the reed switch and its just 2 wires that go in to the cdi with nothing in between and there were 18 wires.
              @Mr-Shadi
              Any progress?…
              It is weird that it activates if you move it away from its spot. Are there any other wires going into your speedometer apart from the read switch ones you’ve mentioned, and the two for the bulb? (blue & black on mine) I’m wondering if the ‘activator’ in the speedo is electrical or magnetic/mechanical in some way…
                @Mr-Shadi
                Any progress?…
                Mr ShadiM Offline
                Mr ShadiM Offline
                Mr Shadi
                @SpookDog I GOT IT! I derestricted it. It took me a long time and a lot of anger but i DID IT! I did it by cutting the reed switch wires and putting the reed switch in its place with exposed open wires. Then i turned the bike on and kickstarted it, after that i revved till it hit the rev limiter and connected the wires till the rev limiter passed 6.5K without staying stuck and taped up the wires so they don't touch (Not the wires that are on the reed switch. The ones that come to it) and put them away. now the bike accelerates beyond 80km/h 50mp/h.
                  @Mr-Shadi
                  Sweet! I’m happy for you bud 🙂 …
                    @Mr-Shadi
                    #63
                    @Mr-Shadi
                    So disconnecting the wires while the revs were above the limiter somehow reset the CDI?…
                      markus.wM Offline
                      markus.wM Offline
                      @Mr-Shadi bloody hell mate, if you scroll down through this thread you'll see that's exactly what I told you to do back in April. Glad you finally got it anyway. Happy days.
                      S Mr ShadiM 2 Replies Last reply
                        #65
                        @markus-w
                        We’ve all got bad memory mate, goes with being human 😛 …
                        If I don’t write things down I end up doing crazy spinning circles 🤩
                          Mr ShadiM Offline
                          Mr ShadiM Offline
                          Mr Shadi
                          @markus-w
                          You told me to cut the wires and keep them apart lad. That didn't work, what i did was i cut the wires and connect them at the right time to somehow bypass the restriction.
