  3. Top End
  4. Athena 125 with Athena pipe on dyno
16 Posts 6 Posters 3.2k Views
  • R Offline
    R Offline
    Rallyfinnen
    I found a lot of info here, but not much dyno results, so I thought I would register and contribute.
    Background:
    The DTR was a boyhood dream when it came out (yes, I'm old), and when I saw a -88 (3MB) for sale nearby, I had to take a look. I ended up buying it even if it's old and abused. But, I see it as a hobby project, and the intention is not to do a total restoration, but just make it a usable toy. Not many around for sale in Sweden either.
    I'm a two stroke nerd, so engine is first on the list 🙂
    The standard exhaust was rusted, so I got an Athena exhaust for it mostly based on price, and that it has an Athena cylinder. Not a lot of info to be found on the character of the pipes, so not easy to make an objective choice. I also replaced the piston since it had some scoring from dirt getting in via the rusted exhaust. Cylinder is not mint, but usable.
    Anyway, I did a few dyno runs today, and the setup is the following:
    Athena 125 kit, 0,8mm squish
    Athena exhaust
    Stock 26mm round slide Mikuni carb, with stock jetting
    Regular 95 fuel with abt 3% Motul 800 premixed
    Dyno is an inertia dyno owned by a friend. Inertia has been calculated in CAD, and I trust the values are as accurate as they can be, and so should the calculated power. Software is GSF dyno. Power will vary from day to day based on weather anyway. Best to do comparisons/tuning on the same day under same circumstances. In this case I just wanted an idea of the character, and get an idea of how well the power valve and ignitions 'maps' was working together with this combo.
    I tried advancing the ignition by moving the trigger a few mm by filing the holes, and that resulted in a minor power loss, so no more advance needed, possibly retard would be better.
    Power valve seems to perfectly fill the hole between the curves i got from running it in closed and open positions, so nothing to be gained there either.
    Jetting seems pretty ok, plug has a nice color. I'm guessing it would be slightly rich if there was no oil in the fuel though.
    Seems uploading images failed..(image size too large) Will add another post if I get it to work.
    • R Offline
      R Offline
      Rallyfinnen
      No luck uploading, tried to make image smaller, but still get the error message.
      Here is a link to the image on another forum, hope it works
      http://www.warp7.se/forum/files/thumbs/t_athena_125__exhaust_std_ign_vs_ypvs_open_vs_closed_108.jpg
      Red is with power valve open, black is closed, and green is operated by the servo.
      Still unclear I can see. Try this link to go to the post and download the graph from there.
      https://www.warp7.se/forum/viewtopic.php?t=2428&postdays=0&postorder=asc&start=195
      Peak power was 18-19hp between runs.
      • R Offline
        R Offline
        Rallyfinnen
        BTW, here I found some info on the 3MB ignition curve:
        http://tzr4dl.com/dt125r-3mb00-cdi.html
        This guy has really done a lot of interesting stuff on the TZR engines
          @Rallyfinnen Yes sorry I don't support image hosting as it's very expensive on resource and bandwidth.
          I recommend uploading to Imgur and linking it from there.
          That looks promising figures though.
          I run the Athena 170 kit with an underslung, VForce3 Reedblock, Zeeltronic and a VHSH32 carb. I will get my bike on the dyno one day but I expect it will do well. It pulls nicely.
          • R Rallyfinnen
            HOTSHOT IIIH Online
            HOTSHOT IIIH Online
            @Rallyfinnen All pretty interesting stuff, thanks for posting. I bought an Athena 125cc cylinder kit to do a DTR engine build last year, the bike is now sold but I still have a full set of Athena 125cc A, B and C piston kits (there's like 0.01mm difference in size between them). Replacing the piston often on cylinders with plated bores helps preserve the roundness of the bore for longer (hence why I bought them), if you'd like to buy them from me let me know and I'll do you an eBay listing.
            • R Offline
              R Offline
              Rallyfinnen
              @HOTSHOT-III Thank you for the offer on the pistons, but I don't think I'll be needing them.
              I have a 170-kit on the way too, I think the bike needs a bit more power (mostly low/mid band) to make it more enjoyable to ride.
              I used photobucket extensively years ago, until they ransomed the pictures. I refuse to make the same mistake again.. Maybe limited image size would be an alternative? 1MB images or even smaller should be pretty sufficient. People tend to upload the mega-resolution pics that phones do today, but if resolution is scaled down they are still good enough for forum pics.
              How are the engine vibrations with the 170-kit, compared to standard? Have you adjusted the balance factor (crank & balance shaft) to the new piston weight? I don't like engine vibrations, makes it tiring to ride the bike, so I worry about that with the 170-kit. The plan is not to open the engine atm, just install the kit.
              • Hark_PtooieH Offline
                Hark_Ptooie
                Those 19 hp - are they on the back wheel or crankshaft?
                Original spec is 23 hp (crank), so if 19 hp is wheel then that would suggest 21% loss in transmission which sounds a bit high for a motorbike.
                Of course a 35 year old bike is expected to lose some, I'm just wondering.
                  The 170 kit on my setup is bloody awesome! I love it so much I bought 2.
                  Is it as fast as my RS or Cagiva... No. But I learnt long ago that the DT just isn't that type of bike. I have had my Athena ported and the bikes tuned and it rides just lovely. Pulls really well and is so much fun to ride!
                  With regards to vibrations, yeah that could do with dialing out. After long rides it feels like I have haptic feedback on my phone switched on. But I ride invariably so it's something I can live with.
                  I will get my bike dyno'd this year and post up the results...
                    I get numb fingers, especially on my left hand where I rest them on the lever. I even looked into rubber mounts for the bars! 🙂 …
                      Hark_Ptooie
                      Piston and crankshaft counterweight should match each other. Increase the mass on one keeping the other the same causes more vibrations.
                      In fact, there are two optimums regarding the counterweight - one gives the least vibrations but a bit more bearing load, the other the least bearing load but a bit more vibrations.
                      Extra balance shafts are typically removing secondary vibrations from the conrod, so if the mass of those is the same they should still be right.
                      • Hark_PtooieH Hark_Ptooie
                        Interesting, I would love to be able to dial away some of the vibration. It’s such a high frequency it sets my bones on edge sometimes…
                        I had a really strange thing happen a couple weeks ago. I was waiting on a roundabout to pull away and a car came by towing a huge caravan. It had the absolute worst squealing brakes that I’ve ever heard! The strange thing is my bike seemed to ‘pick up’ the frequency! The rest of the ride home my engine & expansion chamber was ‘ringing’ with weird harmonics! I Shit you not! 🫤
                        It sounded kinda like an overhead camshaft that was lacking oil! WTF?!…
                          @SpookDog Well, sounds like you need to add some more oil to your cams...
                          S OllieDTRO 2 Replies Last reply
                            I’d have to travel back in time to 1988. The year I put mineral cooling oil in my gs125 by mistook 🙂 …
                              OllieDTRO Offline
                              OllieDTRO Offline
                              OllieDTR
                              Hi mate hope you’re keeping well.
                              I’ve just bought a 170kit what carb and jetting do you use?
                              I’m tempted to get a 32mm carb but would standard tm28ss be the same?
                              Thank you
                              • OllieDTRO OllieDTR
                                Thank you
                                @OllieDTR
                                You may as well stick with the standard carb (&jetting) until you’ve run in the new top end. Ain’t gonna notice the extra 4mm of carb unless the throttle is wide open above the 28mm’s area…
                                  I have the Dellorto VHSA 32mm Carburettor as found on the Rotax series of engines. I originally source a 4DL carburettor and saw another VHSA on eBay. I made a very good one from both of them, thinking at the time they were the same. They were not and therefore jetting on my DTR is WAAAAYYY different to that of the 4DL VHSA.
                                  All I will say is, jet to suit, what works for my setup (bearing in mind how unique my setup is) may not be good for you.
                                  But in essence, it's like a 140 main jet with a U13 needle (IIRC) But I bought the whole range. I don't run oil pump and have advanced the ignition + ported barrel with VForce4 Reeds and airbox delete with an underslung pipe. All of those will have factors on jetting so kinda take my setup with a pinch of salt.
