  4. Runs with choke
Runs with choke
76 Posts 6 Posters 19.4k Views
    The airbox on the DTR is pretty restrictive to be fair. Was a common modification by a lot of people tuning their DTRs to cut the entire top section of the airbox off, when these bikes were a dime a dozen.
    I purely ran a pod filter on my DTR and am very happy with how it performs. Cutting the box these days seems sacralige but that's just how it was back then.
    Either way, when you're diagnosing faults it's always good to go to known working.
      #34
      The only thing that the pod filter would affect would be the power jet…
      Ram Air used to make a kit for the Z1000’s (back at the end of the last century!) they used to supply a drill tap and ‘recalibrated’ screw-in brass jet because it looses some of the ‘suction’ caused by the standard long air intake. Interesting stuff!…
      OllieDTRO 1 Reply Last reply
        @OllieDTR
        Have you checked the gasket on the carbs slide body? Or the slide top? Anywhere that unmetered air can be getting in? Cracks in the rubber mount even? I personally can’t see the air box being the problem, but it’s a good idea to put every variable back to standard…
        If it helps I’d be up to lending you my spare carb to see if swapping it out makes any difference. The jets I have for it are richer, I accidentally opened up the .25 pilot and I only have an aftermarket 250 main for it, but it works…
        It’s in Poole…
        PS have you got the little tube connecting the power jet from the throttle body to the bowl? If that wasn’t connected it could suck air in there…
        OllieDTRO
        OllieDTRO
        OllieDTR
        A different carb sounds like my next step mate after the snorkel as I can’t think where it could be coming in now, everything is sealed with new gaskets so if it’s not the snorkel it’s the carb,
        I’m in Weymouth Dorset so only down the road, I might have to take you up on the offer of borrowing it mate to see what it idles like if that’s the case I’ll be purchasing one soon as I know
        Thank you
          OllieDTRO
          OllieDTRO
          OllieDTR
          The only other thing I can think of air getting in is…
          So the reed rubber bit where it goes onto the reed valve that has its own gasket doesn’t it the rubber bit, I’ve put a gasket onto that as it’s got a reed spaced air wouldn’t get in there would it? Or would it be best to take that gasket out and just put it without as it is from factory?
          Thanks
          • MadGyverM
            MadGyverM
            Is the rubber joint for the carb ok, maybe has a crack and with the vibrations from a running engine sucks air or it's become too stiff and doesn't seals properly with the carb.
            • OllieDTRO OllieDTR
              Thanks
              #38
              @OllieDTR
              There’s a gasket below the metal reed valve. None above (and between) the reed valve and rubber intake (it has its own seal). If you’ve fitted one strip it down and try again. The inlet is the most likely cause for your symptoms…
              Do you have much hands on experience with engines, or is this a first bike?
              One of my first experiences with the dtr was an almost Invisible split in the rubber mount…
                @OllieDTR
                Have you changed the jetting, or is it the same as in the start of the thread?
                210
                .225
                Ect?
                  210
                  .225
                  Ect?
                  OllieDTRO
                  OllieDTRO
                  OllieDTR
                  I’ll take the gasket off today mate, I’ve had a couple dts and mx bike I’ve always done rebuilds on but this one seems to be testing me…
                  I’m currently running 240 main
                  25 pilot
                  Went for a ride on choke then turn choke off when moving goes for Abit then bogs when let off and try to use throttle again just bogs but flick the choke back up and runs again
                  Am I thinking it’s lean?
                  I’m off to get some brake cleaner in a minute and going to test for leaks again
                    25 pilot
                    #41
                    @OllieDTR
                    It’s definitely lean. It’s just where the fux it’s taking unmetered air at? The power jet pipe is connected, yeah?
                      @OllieDTR
                      OllieDTRO
                      OllieDTRO
                      OllieDTR
                      Powerjet is connected, I’ve blasted brake cleaner around everywhere and no change in revs, I’m going to completely take the carb apart everything and clean and check everything
                        @OllieDTR
                        I had to ask, I honestly don’t think that you’re as big an idiot as me 🙂 I just don’t understand where an air leak big enough that changing the jetting as you have, has made no difference, can be…
                        Again, sorry, I have to ask! You are spraying and checking while the choke is off? When I sprayed even a tiny bit near where the leak was my engine stopped ‘hunting’ and settled down.
                        Yours will tick over without choke yes? But be all ‘fast & twangy’?
                        There are only so many places air can enter unmetered
                          @OllieDTR
                          OllieDTRO
                          OllieDTRO
                          OllieDTR
                          Fixed it!!!
                          So airscrew didn’t have a o ring so put one in.
                          Also when I was checking air leaks nothing, so I thought I’d take carb out and check all rubbers, where the jubliee clip tightens up onto the carb on inlet there was a hairline crack under the clip which I only saw when I flexed it about. so put the carb back on and sprayed like 2mm away from the place I saw the crack and sure thing revved up. So that’s why I didn’t rev before when I sprayed because I had to be really really close to it!
                          After all that 😅 I’m glad though crazy how a tiny tiny little crack can do that but where it was hidden under the clip it didn’t pick up the brake cleaner until really close.
                          Thank you everyone been a couple of stressful days but that’s a win and learn something on the way
                          3
                            Fixed it!!!
                            @OllieDTR Cool you've fixed it 👍 👍 Here you go bud, DTRe 1D01-1D03 (2004-onwards) wiring diagram as discussed:
                            I'd still try those washers above and below the carb needle E-clip, stopping that moving up and down too much will be no bad thing. And here's a pic of my airbox when I sealed it up, this is why I like to take them out to do this so the part you've glued can sit on the bench horizontally while the glue goes off. While you've got the Seal-All out you can also replace the foam on the back of the filter element holder where it slides into the airbox as this is another thing "previous owners" miss, it rots out providing another route for dirt to get in. 5mm air filter foam is pretty cheap on eBay etc.
                            https://www.repairingproducts.co.uk/product/seal-all-gas-oil-resistant-adhesive/
                              Fixed it!!!
                              @OllieDTR
                              Fuxin sweet! All you have to do now is make sure you got the right jetting for the carb! 😛
                              Have you got another rubber inlet? I can probably flog you one if needed. I went through a spell of snapping them up after I had my ‘cracking up problems’…
                              I did ‘inject’ silicone sealant into the split and around it for a temp fix. Nothing beats a good seal though…
                                @OllieDTR
                                OllieDTRO
                                OllieDTRO
                                OllieDTR
                                Result ay mate! Was on the phone with @HOTSHOT-III and we was running through some stuff and made me think to double check and check again everything.
                                I’ve just picked my spare one up from my mums so will be putting that one on tomorrow.
                                As regards of jetting I’ve got
                                4th clip on needle
                                240 main
                                .25 pilot
                                I’m sure that’s correct for my year as it’s an DTRE engine.
                                I just wasn’t sure if I needed to upjet at all as I’ve got dep, Boyseen dual stage reeds and 1mm oversize re bore?
                                I will do a plug chop when it’s all running properly and go from there
                                • OllieDTRO
                                  OllieDTRO
                                  OllieDTR
                                    Sounds like it's running lean on fuel then. There is a good guide on here to jetting. Sounds like you've got either two options.
                                    Put it back to standard, or jet to suit. I'd just do the latter. A bit of playing around, but you'll get it I'm sure.
                                    • OllieDTRO
                                      OllieDTRO
                                      OllieDTR
                                      @SpookDog @HOTSHOT-III
                                      I feel like a right idiot…
                                      So the main problem was the split in the inlet rubber got new one on. But when I was changing the jets I had a jet that came in the carb already and that 20 pilot from mikuni I put it next to a .20 pilot I had from my new jets and the new jet holes was tiny compared to this one, to get the same size holes from my new jets compared to this 20 I had would be like a 35…
                                      Never buy jets from eBay that’s a Chinese seller I guess
                                      So anyways my mates got a dt so I rang him up and borrowed a 25 pilot and sure thing it ran the sweetest ever!! So now I need to order a 25 pilot from a good company also will probably get a 240 main jet aswell while I’m at it
                                        #51
                                        @OllieDTR
                                        Bud! I’ve done the fleabay SHITTY jet thing myself. Don’t beat yourself up, it’s all a learning curve 🙂 …
                                        I got a good aftermarket .25 jet from
                                        Sportaxracing. The difference it made to my bike was unbelievable. Starts first kick, ticks over and revs up crisp and clean. It’s where I’d go…
                                        I’ve also bought ‘EBC’ jets that were shite, because getting a Mikuni genuine.25 is impossible in the UK. I don’t know if a genuine 240 is possible either…
                                        I’m happy for you that it’s running sweet! 😇
                                          @OllieDTR
                                          OllieDTRO
                                          OllieDTRO
                                          OllieDTR
                                          I was annoyed but pleased at the same time I finally narrowed it down mate!
                                          What do you think of these?
                                          https://jetsplus.co.uk/product/mikuni-pilot-jet-vm22-210-ax100-en-tzr-tm-2-stroke-4-stroke-10-65/
