  3. TZR
  4. What was I thinking!…
128 Posts 6 Posters 65.5k Views
    Guide Bushes turned up but are too big. The size I need is
    42mm outer
    39mm inner
    20mm deep
    1.5mm thickness
    I can’t find them anywhere. If anyone knows of a place, please let me know…
    Help! 🤯
    MadGyverM
    MadGyverM
    @SpookDog Have you thought of custom made to a machinery shop?
    • MadGyverM MadGyver
      @MadGyver
      I think my only real option is to have the fork legs opened up from 42mm to 43mm (the bush fits the stanchion perfectly, it’s only the outer size that’s wrong)
      I just don’t know how much meat there is left to lathe out…
        @MadGyver
        #95
        But I’ll worry about that when I have the money to pay for it 😛
        Plan of action: Ready frame into enough of a rolling chassis to fit engine.
        1. Clean rear shock for refitting.
        2. Clean & grease swingarm bearings, bolt, bushes & endcap/seals.
        3. Temporarily fit forks for symmetry.
        4. Clean & prep front & rear wheel bolts, spacers & adjusters, ect.
        5. Whack it together…
        I ground off the rust and gave the swingarm & down tubes a temporary paint job, because they were pretty scabby. Angle grinder then rust converter, then zinc primer, then (apparently!) aluminium- silver…
        TBC…
          TBC…
          #96
          Baby steps is still forward steps! 🙂 …
          Been busy enjoying the weather but still managed to get a little bit done!
          I definitely need to get the new bushes fitted in, there’s loads of stanchion movement in the fork leg. I just need to find a trustworthy engineer with a lathe…
          The bump stop rubber has rotted out on the rear shock. I need to find a replacement that can be fitted in situ, if there are such things that anysoul knows of?…
          So quiet! Is everything hibernating already? …
            I forgot!…
            Any experience with Linkseal Oko? I’ve only just discovered this kind of product. It sounds too good to be true! But the theory/idea makes sense as long as it performs as it says…
            MadGyverM 1 Reply Last reply
              I forgot!…
              MadGyverM
              MadGyverM
              @SpookDog said in What was I thinking!…:
              I forgot!…
              Never heard of it but looks like stuff that put on bicycle when the tubeless conversion on spoked rim is done.
              If it's quality stuff it will do what is advertised.
                I forgot!…
                #99
                @MadGyver
                Sounds right!…
                Put it in and it coats the inside of the tyre & rim and stays liquid, if you ever get a puncture it will be forced out into the puncture hole and seal it. Sounds almost too good!
                But!: From what I’ve read a lot of it is agricultural and off road based, which is only a good thing to my thinking…
                I can’t believe I’ve never heard of it before…
                Another piece of the puzzle connected!
                One day I’ll get a bike that comes in one bit without the challenge of sussing out how it all fits together 🫤 …
                Maybe, but where’s the fun in that!
                  @MadGyver
                  Sounds right!…
                  #100
                  Tzr125RR tailpipe…
                  Man this thing is heavy! as well as looking like it was used as a bobsleigh! 😜 …
                  WTF is that inside?! Someone left a WW2 torpedo inside!…
                  Is this normal or was this an asthmatic example of Yamahas finest? This ‘can’ weights about a kilo, no shit!…
                  It’s weird cause the expansion chamber breathes really well with no obstructions, though it ways a Shit ton as well!!…
                  This was not an easy picture to take, that spot of light is the only ‘free airway’ through the can! It was only visible if I angled it’just so’…
                    Tzr125RR tailpipe…
                    #101
                    I seriously can’t believe that a tailpipe would be so restricted!
                    This is what came out:
                    This is what any exhaust gas faces when exiting the expansion chamber:
                    I’ve got a Big1 tailpipe I’m going to try and fit to the expansion chamber. I ran a clutch cable outer through it just to make sure it wasn’t severely baffled as well! TF it’s clear!…
                    Are Dtr tailpipes like this? They’re definitely heavy enough!…
                      @SpookDog Stock DTR tailpipes are like your TZR-R tailpipe; you can't see through them at all. I've never considered the stock DTR tailpipe to be a restriction, all mine with stock exhausts have revved to 10,000rpm+.
                      I did however once bolt a brand new DEP silencer on to the stock front pipe on my '93 3NC, and the bike immediately refused to rev any higher than 9,000rpm. I tried it in several different directions to rule out headwinds etc. and it just would not rev out fully. Refitting the stock tailpipe cured this straight away.
                      Your front pipe looks very similar in construction to a stock DTR front pipe as well so until you've rebuilt and run in the engine and properly assessed its performance, I'd resist the temptation to do anything irreversible to the exhaust.
                      Lots of people "gut out" the stock DTR front pipe in the mistaken belief it will liberate a ton of extra horsepower but it often makes it slower. The DT125R/DT200R styling was based on the 1988 YZ250 and the expansion chamber is about the same physical size. Within that there was enough space for an appropriately-sized, functioning expansion chamber for a 125cc road/trail bike and enough noise suppression material for the bike to pass a noise test (whereas the YZ is for closed-course competition which is why it has a single-skin racing exhaust). If you chop it open with an angle grinder and rip all that stuff out, it will not only sound like a wasp in a tin can but also you’ll probably lose power as you no longer have an expansion chamber which matches the porting/carb/crankcase volume etc. By all means bolt on an aftermarket silencer and try it but from your pics, I'd be surprised if the stock silencer is restrictive. Probably more likely it's like that to manipulate sound waves to pass a noise test so the owner doesn't have to suffer the hassle of repacking the silencer periodically.
                        I dunno bud. I thought that the pressure pulse/wave was all done in the expansion chamber? I know SFA about 2T exhausts though, only the very little I’ve read online. It’s moot for me anyway. The doodle-bug bit is supposed to be welded into the end can. It’s basically fallen apart 🫤
                        Big 1 or bust! Saying that I do have an aluminium giannelli kicking around somewhere …
                          #104
                          @SpookDog Yes the expansion chamber does the lion's share of controlling the pressure waves but the end can plays a part as well, and they need to be matched to one another. And road-going two-strokes are something of a special case; making an engine deliver the addictive two-stroke sound/power delivery and making it quiet enough to be acceptable to the general public is a tall order compared to just punching out a production run of YZs for the track. I used to wonder how manufacturers could afford to redesign MX bikes every year but in truth you don't even get a warranty of any value when you buy a brand new one, let alone having to pass an MOT or noise test and this is where a lot of the R&D money goes on road bikes.
                          RGV250 standard cans weigh a ton and are silenced in the same way as your TZR can and a good stock one of those is good for 60bhp/130mph. Once on a summer's evening I was greenlaning up at Pepperbox Hill when I hadn't had my 3NC for very long, I slowly passed this family with young children and met up with them a bit later when I stopped, and they commented they thought I was riding an electric motorcycle when they saw me coming towards them! 5 minutes later Greta (use your imagination) and myself were doing 70mph on the dual carriageway towards Salisbury with a bit in reserve.
                          In truth I don't really know one way or the other, but testing both setups back to back should prove interesting 👍
                            Seeing as the original tailpipe is busted I decided to use some of it to make another.
                            I cut the threaded ring off of the bit that was snapped off from the inside of the original.
                            Then I cut the excess jointing pipe off of the big1 tail pipe.
                            So I could join it to the big1 tailpipe.
                            I drilled holes in the big1 to match.
                            Then used Allen bolts to join them.
                            The idea being it ‘locks’ the Allen bolts in place and lets me use the joining gasket from the original. So I can remove the big1 tailpipe without having to dismantle it to get to the Allen bolts heads, if/when I want to remove it. I just have to undo 3 10mm nuts.
                            End product:
                              #106
                              I do hear what you’re saying. I swapped the standard & big1 tailpipes around on my dtr a few times, for MOT and because my expansion chamber was a big1 as well. It never made any noticeable difference to the ride~feel or power. It was just the standard can was so stealthy! I’m 53 years old and am not into noisy pipes in any way at all! 🙂
                              I just assumed that it was a restriction because I’ve never seen the like before. Hindsight makes me realise it’s made that way because it’s a non serviceable part made to last forever. I love the build quality and finish of the front/expansion chamber as well! Double skinned, stove enamelled. Over engineered goodness! That front pipe is 30 years old!!…
                                Good man! That's looking decent 😃
                                  End product:
                                  @SpookDog Bud, that looks factory! Nice work 👍
                                    #109
                                    Cheers guys! I only hope that it works 🙂 The big1 is like any other aftermarket one, it has nothing but a pierced hole tube with fibre wadding. I’ve got the carb and air box fitted. I just need to add the loom and a battery to fire it up. Monies are tight though, I’ve gotten my tax & mot & insurance all due this month 🤪 …
                                    I do have the rubber repair kits for the front brake master & calliper to be getting on with.
                                    I’ve stripped the rear calliper without breaking anything, just need to order repair kits for it and the 13mm Brembo master that it uses…
                                    Wish me luck, please!…
                                    One step closer…
                                      One step closer…
                                      #110
                                      Found out that the FZ600R uses the same Sumitomo callipers as mine. There’s a pair of them on fleabay for £65, in excellent condition with pads! I wish it was one of the times that I had monies!! 🙄 …
                                      I would love to put twin discs on this!…
                                        #111
                                        Actually they are similar, not identical! 🙄
                                        One thing I really am not keen on is the big fat 250 ass on this bike. It looks kinda stupid with the 150 tyre under it. I want to find a nice slimline single seat pod to fit to it. Any input appreciated…
                                        I’m thinking 1980’s gsxr slab side kinda thing…
                                          @Calum I thought only 250cc+ Yamahas had the third cable from the YPVS servo to the oil pump, so I looked at the 4FL TZR125R on Yamaha France and sure enough, it's shown as part of the throttle cable!
                                          It's known as a "see-saw linkage" and its purpose is to further increase the oil delivery rate when the YPVS opens and the bike comes on the pipe as this is a high load application when the engine needs a lot of oil. It was fitted to the TDR and TZR250 parallel twins and probably the Reverse Cylinder and V-Twin TZR250s as well.
                                          I was very surprised to see this on a DTR-derived engine, I guess this combined with the strange looking ignition advance curve and plated bore as standard all point to the fact that the TZR125R is meant to rev a lot higher than the 10,500rpm you can expect from a well-sorted stock DTR.
                                          https://dt125r.co.uk/post/30119
                                          Interestingly the original 2RH TZR125 which was released in 1986 was also well-known to rev to around 12,000rpm when derestricted, and whilst they didn't have a plated bore the 2RH cylinder and head did have a weirdly enormous water jacket, I mean they were roughly the same physical size as a Suzuki TS250X top end or something like that. Looking at mates' TZRs as a youth I always thought it looked a bit out of place sat on what were basically DTR crankcases (the TZR125R plated cylinder is outwardly the same as a 3MB DTR cylinder IIRC). I think this was an attempt to achieve the required heat transfer into the coolant for those kinds of engine speeds without the expense of a plated bore as this was fairly new technology in the motorcycle world in the mid 80s.
                                          I must admit I was never a fan of the 2RH engine, I knew a few people who made them quite fast but they had a weaker clutch than the DTR, and also a particularly horrible front sprocket retention using one of those little locking plates and two M6 bolts like a C90 step-thru meaning if you buy a 2RH TZR125 to restore today, you can pretty much guarantee a knackered output shaft. And very low compression for some reason, whenever someone let me have go on one I thought it had blown up just kicking it over. Yamaha made some intelligent mods to make it strong enough for DTR use.
                                          Re: the see saw linkage. I read somewhere that it’s for during overrun, when the revs are above 6-7k but the throttle is closed. It kinda makes sense as it’s activated by the power valve servo? What you recon?…
