  3. Welcome New Owners!
  4. Hello all
Hello all
58 Posts 5 Posters 25.1k Views
    @mcludd Yes, this bike seems to have been butchered around. That stator is not for that type of ignition system.
    I cannot comment on whether "it'll work" or not, however as you've pointed out, it's not the correct CDI for the year and these things can be difficult to diagnose when it is all a mishmash and without official Yamaha knowledge.
    What I have done in the past is swapped out the entire ignition system to match compatibility. I ran an earlier engine, swapped out the crank/flywheel and stator together to use a newer ignition system. Since that means splitting the cases, it's involved, that's okay I was rebuilding the engine, had the cases already split deciding what to do. It involved plenty of research before hand chatting to @scrimsmustang to understand the picture.
    I can see the correct CDIs on ebay:
    https://www.ebay.co.uk/itm/305299020174?hash=item47153d598e:g:TJkAAOSwSAFlbQko&amdata=enc%3AAQAIAAAA0JV5FQjdwZXK%2BV5F2MV8Re3FLVtTMaqk%2B1SjDSMkU7bF4QDwjLDuH2WUKRNSd0h6IP8pniDc4wGArTwAIVNMp0fgVhPNYkhoViDOS465RrGNm6BSrSr1Im0QJRy3R%2BSq9T7pwpOZPh5r0bBBlaorlCCAdWEjchaKTL4rUJtmaZY1K6JPakwx%2FeyciLApHHtm7I0snFk%2BlUR%2BUzyhz6uc6RW66v27E18HnCm3Hc3srqTBv1BMCb%2Fgz6g12jb71N10SS%2Banx%2BmY6a8WPY4T5B7JdQ%3D|tkp%3ABk9SR7iX8M6GYw
    https://www.ebay.co.uk/itm/375093889155?hash=item5755568883:g:ysIAAOSwaddlaeZv&amdata=enc%3AAQAIAAAAwP5VylX9Bxl5XJe0hoBxOJUjyAh02Xio4KmVKz23Al6VUK64Mo2fJIgVASoE7iwodqbYlpWeZdU87aGVSsqnvAr3%2FZZYCTOIatChE5%2FL%2FOokyHH5zVV3DVP924u%2F3UMIB%2FZGogvFaJIgBjMfOWomyKsdg6OSLq%2FoDy1wAHN4766Yxp28wwa3iBEqhsKKPNH3neZp7Zk0xB4xh6rxek41mhlgSaNe3vemIZV3nU6%2BRPLaAIrTqbwy1dN0qZEl2SUvZg%3D%3D|tkp%3ABk9SR5iZ7M6GYw
    If it were me, I'd be looking to restore the original CDI, or better still get an Ignitech or Zeeltronic as the CDIs I've linked you to can be terribly restrictive.
    One of those CDIs should be the one you need, I don't know for certain you'll have to do some digging around.
      #29
      There is a place in France (ask hotshot) that sells a conical ‘shim’ that fits over a non RE crank that will make it accept the back to front rotor. All you’d need then is an ally side casing (which I have a spare) and an RE stator & rotor …
      That should make it plug and play again!…
        I don’t see any way that a late RE loom will mesh with an early CDI. I thought it had the original RE motor in it with the reversed rotor and coils bolted to the side casing…
          #31
          fleabay
          Don’t have rotor tho
          cone shim
          Ouch£€$¥!!…
            @mcludd I literally fixed and then @ you about how to embed photos #12.
            M
            M
            mcludd
            wrote on last edited by mcludd
            #32
            @Calum said in Hello all:
            I appreciate the fixing but I haven't a clue what (www.example.com/image.jpg) means I'm afraid
            • M
              M
              mcludd
              Wowee 69 european pounds for a shim then a cover a rotor and a stator, sounds like heaps of money to me.
              I will see what the whole lot is going to come to and go from there
              • M mcludd
                #34
                @mcludd
                What did the bike cost?…
                When you’ve hosted a pic at Imgur, or whatever. At the top of your post, on the tool bar, there is an oblong that looks like a picture frame with 2 mountains and a star (between the 2 chain links and the smiley face) Tap that then paste in the ‘copy link’ from Imgur. It will show your pics…
                • M
                  M
                  mcludd
                  1500 quid
                  • M
                    M
                    mcludd
                    #36
                    ![alt text](image urlhttps://imgur.com/WMVHrzb![alt text](image url)![alt text](image urlhttps://i.imgur.com/WMVHrzb.jpg
                    • M
                      M
                      mcludd
                      ![alt text](image url[img]https://i.imgur.com/WMVHrzb.jpg[/img]
                      Tried and failed I think?
                      • M mcludd
                        1500 quid
                        @mcludd
                        Gonna be a couple hundred quid. The feabay seller problem has the rotor. The shims the fuxor! Can’t be easy to make that puppy though!…
                        Still a viable bike if it’s in good enough condition…
                          @mcludd
                          #39
                          The copied link has to go between the ( ) brackets
                          Make sure the ‘image url’ is deleted if the paste doesn’t go smoothly. Otherwise I’ll corrupt…
                          • M
                            M
                            mcludd
                            ![alt text](https://imgur.com/RM8POti!alt text)
                            By jingo I think I have got it!!
                            • M mcludd
                              @mcludd
                              Getting there!…
                              • M mcludd
                                @mcludd CBR400 Tri-Arm front and rear ends in a KH250? Well done Sir 👍
                                • M
                                  M
                                  mcludd
                                  Good spot, thats exactly what the donor chassis was.
                                  • M
                                    M
                                    mcludd
                                    alt text I decided to concentrate on my other project today, feeling a bit fed up with the water cooled ungrateful Yamaha
                                    • M mcludd
                                      #45
                                      @mcludd
                                      Before my time 🫤 RD 250?…
                                      Edit: 200?
                                      I met a bloke who put an RD 200 twin engine in a dtr125 frame! He was trying to make a 2>1 exhaust the last time I saw him. I didn’t know about 2T expansion chambers at the time! I’ll have to stop by and see what’s what next time the weathers good and I feel any kinda sociable…
                                        Very nice 😄
                                        • M
                                          M
                                          mcludd
                                          So got about as far as I can with the 250 til I get some stuff back from paint so I will have to turn my attention to the ginger stepchild again tomorrow, anyone got a pre 2004 wiring diagram they could share so I can look at how (if at all ) possible it is to fit an earlier CDI
