  3. Welcome New Owners!
  4. Hello all
Hello all
58 Posts 5 Posters 25.1k Views
    @mcludd Yes, this bike seems to have been butchered around. That stator is not for that type of ignition system.
    I cannot comment on whether "it'll work" or not, however as you've pointed out, it's not the correct CDI for the year and these things can be difficult to diagnose when it is all a mishmash and without official Yamaha knowledge.
    What I have done in the past is swapped out the entire ignition system to match compatibility. I ran an earlier engine, swapped out the crank/flywheel and stator together to use a newer ignition system. Since that means splitting the cases, it's involved, that's okay I was rebuilding the engine, had the cases already split deciding what to do. It involved plenty of research before hand chatting to @scrimsmustang to understand the picture.
    I can see the correct CDIs on ebay:
    https://www.ebay.co.uk/itm/305299020174?hash=item47153d598e:g:TJkAAOSwSAFlbQko&amdata=enc%3AAQAIAAAA0JV5FQjdwZXK%2BV5F2MV8Re3FLVtTMaqk%2B1SjDSMkU7bF4QDwjLDuH2WUKRNSd0h6IP8pniDc4wGArTwAIVNMp0fgVhPNYkhoViDOS465RrGNm6BSrSr1Im0QJRy3R%2BSq9T7pwpOZPh5r0bBBlaorlCCAdWEjchaKTL4rUJtmaZY1K6JPakwx%2FeyciLApHHtm7I0snFk%2BlUR%2BUzyhz6uc6RW66v27E18HnCm3Hc3srqTBv1BMCb%2Fgz6g12jb71N10SS%2Banx%2BmY6a8WPY4T5B7JdQ%3D|tkp%3ABk9SR7iX8M6GYw
    https://www.ebay.co.uk/itm/375093889155?hash=item5755568883:g:ysIAAOSwaddlaeZv&amdata=enc%3AAQAIAAAAwP5VylX9Bxl5XJe0hoBxOJUjyAh02Xio4KmVKz23Al6VUK64Mo2fJIgVASoE7iwodqbYlpWeZdU87aGVSsqnvAr3%2FZZYCTOIatChE5%2FL%2FOokyHH5zVV3DVP924u%2F3UMIB%2FZGogvFaJIgBjMfOWomyKsdg6OSLq%2FoDy1wAHN4766Yxp28wwa3iBEqhsKKPNH3neZp7Zk0xB4xh6rxek41mhlgSaNe3vemIZV3nU6%2BRPLaAIrTqbwy1dN0qZEl2SUvZg%3D%3D|tkp%3ABk9SR5iZ7M6GYw
    If it were me, I'd be looking to restore the original CDI, or better still get an Ignitech or Zeeltronic as the CDIs I've linked you to can be terribly restrictive.
    One of those CDIs should be the one you need, I don't know for certain you'll have to do some digging around.
    #29
    There is a place in France (ask hotshot) that sells a conical ‘shim’ that fits over a non RE crank that will make it accept the back to front rotor. All you’d need then is an ally side casing (which I have a spare) and an RE stator & rotor …
    That should make it plug and play again!…
      I don’t see any way that a late RE loom will mesh with an early CDI. I thought it had the original RE motor in it with the reversed rotor and coils bolted to the side casing…
        #31
        fleabay
        Don’t have rotor tho
        cone shim
        Ouch£€$¥!!…
          @mcludd I literally fixed and then @ you about how to embed photos #12.
          M
          M
          mcludd
          wrote on last edited by mcludd
          #32
          @Calum said in Hello all:
          I appreciate the fixing but I haven't a clue what (www.example.com/image.jpg) means I'm afraid
          • M
            M
            mcludd
            Wowee 69 european pounds for a shim then a cover a rotor and a stator, sounds like heaps of money to me.
            I will see what the whole lot is going to come to and go from there
            • M mcludd
              #34
              @mcludd
              What did the bike cost?…
              When you’ve hosted a pic at Imgur, or whatever. At the top of your post, on the tool bar, there is an oblong that looks like a picture frame with 2 mountains and a star (between the 2 chain links and the smiley face) Tap that then paste in the ‘copy link’ from Imgur. It will show your pics…
              • M
                M
                mcludd
                1500 quid
                • M
                  M
                  mcludd
                  #36
                  ![alt text](image urlhttps://imgur.com/WMVHrzb![alt text](image url)![alt text](image urlhttps://i.imgur.com/WMVHrzb.jpg
                  • M
                    M
                    mcludd
                    ![alt text](image url[img]https://i.imgur.com/WMVHrzb.jpg[/img]
                    Tried and failed I think?
                    • M mcludd
                      1500 quid
                      @mcludd
                      Gonna be a couple hundred quid. The feabay seller problem has the rotor. The shims the fuxor! Can’t be easy to make that puppy though!…
                      Still a viable bike if it’s in good enough condition…
                        @mcludd
                        #39
                        The copied link has to go between the ( ) brackets
                        Make sure the ‘image url’ is deleted if the paste doesn’t go smoothly. Otherwise I’ll corrupt…
                        • M
                          M
                          mcludd
                          ![alt text](https://imgur.com/RM8POti!alt text)
                          By jingo I think I have got it!!
                          • M mcludd
                            @mcludd
                            Getting there!…
                            • M mcludd
                              @mcludd CBR400 Tri-Arm front and rear ends in a KH250? Well done Sir 👍
                              • M
                                M
                                mcludd
                                Good spot, thats exactly what the donor chassis was.
                                • M
                                  M
                                  mcludd
                                  alt text I decided to concentrate on my other project today, feeling a bit fed up with the water cooled ungrateful Yamaha
                                  • M mcludd
                                    #45
                                    @mcludd
                                    Before my time 🫤 RD 250?…
                                    Edit: 200?
                                    I met a bloke who put an RD 200 twin engine in a dtr125 frame! He was trying to make a 2>1 exhaust the last time I saw him. I didn’t know about 2T expansion chambers at the time! I’ll have to stop by and see what’s what next time the weathers good and I feel any kinda sociable…
                                      Very nice 😄
                                      • M
                                        M
                                        mcludd
                                        So got about as far as I can with the 250 til I get some stuff back from paint so I will have to turn my attention to the ginger stepchild again tomorrow, anyone got a pre 2004 wiring diagram they could share so I can look at how (if at all ) possible it is to fit an earlier CDI
                                        • M mcludd
                                          #48
                                          @mcludd Here's a 3NC wiring diagram. The DTR used either 3NC or 3MB wiring between 1989 and about 1998; 3MB is almost identical but you can't run a 3NC CDI on a 3MB loom or vice versa.
                                          I don't know very much about the '99 onwards wiring which incorporates the reed switch etc but the 3NC and 3MB platforms (and the 3DB from the original round slide carb DTR in 1988) are all full power, even on UK bikes which were just supplied without the YPVS servo and the powervalve pinned closed for the 12bhp learner legislation of the day. I'd steer clear of 3DB electrical parts as the '88 bike had a different bore and stroke to '89 onwards DTRs.
                                          To run 3NC or 3MB electrics, of the top of my head you'd need:
                                          CDI unit and main loom
                                          Stator and flywheel (part numbers are different between 3NC and 3MB)
                                          Non-DTRe crankshaft if your bike has electric start
                                          Regulator/rectifier
                                          3-wire YPVS servo (the 3-wire servo has its own on-board computer and so only requires an RPM signal from 3DB/3NC/3MB CDI units)
                                          Pattern 6-wire ignition switch
                                          Left handlebar switch cluster
                                          Clocks for temp gauge wiring
                                          Twistgrip (the type with integral kill switch)
                                          Poss. sidestand switch
                                          These electrical platforms are a good deal simpler than some of the later bikes and as far as I'm aware the left crankcase has all the correct mounting holes for the non-DTRe stator even on electric start bikes so if you can get hold of all the above parts it could be the easiest way around this. Also if you look around, back in the day there was such a thing as a 3MB DTRe which would be the best electrical platform to go for IMO if you wanted to do this. At one time I owned three French import DTRs; '93 and '98 3NCs and a '98 3MB. All full power (10k rpm +) but the 3MB had noticeably more power than the other two despite having over 65000km on the clock (the 3NC and 3MB have different ignition advance curves).
                                          The KTM LC2 125 had a DTR engine and ran the 3MB electrical platform so have a look on eBay international for a CDI and servo off one of those, German and Austrian breakers are full of them.
                                          Anyone can see anything I've left out please feel free to add to this!
