1.1k Posts 26 Posters 649.2k Views
    The umbrella? 😜 …
    Blaster 200 small end bearing didn’t fit. Was too wide to fit inside the piston. Luckily I had a dtr bearing that has wider roller/needles than the others I’ve got. Even with a bit of side to side play it still has good coverage of the conrods top eye width…
    PS I just noticed that the Athena top end gasket set doesn’t include the orange PV bush seal! For nearly £50 you’d think they’d include it?!…
    #806
    Ready to drop in. All torqued and tight! Only the 2T pump left to fettle, I’ve got 3 to find the bestest one. I can finish off the tank of premix anyways 🙂 …
    Just gonna replace the rear shock while the swingarm bolt is out. It doesn’t feel broken but it was crusty 30,000 miles ago. So, yeah! There is that…
      @MadGyver
      Nitro, What is dat? Model fuel?…
      MadGyverM
      MadGyverM
      @MadGyver
      Nitro paint thinner. It dillutes paints and a lot other uses.
        The umbrella? 😜 …
        MadGyverM
        MadGyverM
        The umbrella? 😜 …
        To fit the small end bearing from the Blaster you need to file each side inside of the piston 0,5mm. To be on the safe side I removed 0,75mm from each side for when everything heats and diolates.
        • MadGyverM MadGyver
          The umbrella? 😜 …
          #809
          @MadGyver
          Fux! I wish I’d known that before I buttoned it all up! 😉 …
          I’ve been on a bit of a tight deadline with it, weather wise. Not to mention the strange noises I’ve been ignoring coming from my existing engine. I can’t wait to do an autopsy on it!…
            @MadGyver
            #810
            A little tip for people like me who have to ‘apply’ bearings with a hammer and ‘drift’ 🙂
            Use a jubilee clip to hold in place whatever tool you are using, in my case a screwdriver…
            Make sure it’s clear of the bearing, especially the race. It allows more of the force to be applied downwards, without worrying so much about slipping and destroying the roller~race. It makes the blows less ‘tentative’, more effective. It really makes a difference…
            If you have a suitable tube then ignore me! 😉 …
              I just bought the stearing stem bearing tool.
              https://www.dirtbikexpress.co.uk/products/apico-steering-stem-bearing-installation-tool?variation=51559
                #812
                Then ignore me! 😜 …
                Just found this while looking for some connector blocks and trying to find the proper gauge/amp wire:
                early loom
                OllieDTRO S 2 Replies Last reply
                  Then ignore me! 😜 …
                  early loom
                  OllieDTRO
                  OllieDTRO
                  OllieDTR
                  He makes all types of wiring looms for the dts and he’s local to us
                    Then ignore me! 😜 …
                    early loom
                    #814
                    Just trying to muster energy to strip down for the new motor. Poor old frame hasn’t been tret well by three winters worth of road salt!…
                    Fuxin surface rust everywhere. I dread to think of inside the tubing. I need to get it dipped and coated professionally this spring-summer…
                    I’d like to have a different frame to work on really, If anyone knows of a usable frame for sale, please let me know. 👍
                      @SpookDog I was thinking of getting another frame. I'd like to reshell my '05 into an '88 🤣 By 2028 it'll be MOT/Tax exempt 😛
                        #816
                        Like you need to pinch pennies! 😜
                        I don’t care what year it is as long as it’s not an RE…
                        Going to peices!…
                          Going to peices!…
                          @SpookDog It's not about money, it's the act of having to keep going there. You should have seen the state of my bike when I got it back from them last time. UTTER MONKEYS! Dangerous it was to ride home. And the response "Yeah it would be!" It was fucking sound when I gave it to you 'ya cunts!
                          Anyway, fuming to say the least. And dude! I live a VERY cheap life. Don't smoke, don't drink, don't do drugs (like my coffee), don't drive, don't ride my motorbikes (I cycle/run everywhere). I don't go on holiday and I eat baked beans most evenings, not literally but the cheaper the better. What's the result, a few shiny bolts come pay day. If you examine any photo I take of my bikes, they're usually in the same spots. So I pinch every penny for my addiction.
                            #818
                            Woah there Tiger! I didn’t mean to hit a nerve! Honest! 🙂
                            ☮️ peace!…
                            I’m getting there! I hate working in the damp though! Everything is filthy. I’ve had to scrub up my hands four times already!…
                            PS RE frames are different aren’t they?…
                              ☮️ peace!…
                              @SpookDog Yeah man, no sentiment over text. I'm angry about getting my bike back from the MOT'ers in a sorry state not about penny pinching 🤣
                                I actually believe that 2T’s are ‘rider sensitive’. Other people can upset the whole… vibe, for want of a less hippy word…
                                Did they work on it at all? Or just manhandle it 🙂 …
                                  @SpookDog They decided that the rear wheel wasn't centralised in the swinging arm on my DT, so they fabricated a new rear wheel spacer. This threw the alignment out and when they realised that it would need the front wheel spacers machining, then a new bracket for the caliper being made, they gave up and gave the bike back. It was completely unrideable. Anything over 30mph caused the bike to swerve uncontrollably. I had to ride it back 10 miles below 30MPH. I got it home and the chain had zero slack in whatsoever. I was lucky the rear bearing didn't collapse.
                                  The rear wheel wasn't centralised in the rear arm, true, but it was inline with the front wheel and the front and rear sprockets were aligned. The wheel being central to the swinging arm is irrelevant. The bikes been in this configuration for 10+ years. I threw my original spacers back on and got an MOT else where. They charged me over £100 for the "Privilege". Needless to say, I'm sour about the whole experience. I've been going there years, albeit they've never touched any of my bikes.
                                    That is so very fuxed up 😐
                                    Swingarms are never symmetrical! They always ‘favour’ the sprocket…
                                    I can’t believe they had the front to charge you!!…
                                      I hope I have the energy tomorrow! Also dry weather 😜 …
                                        #824
                                        I decided to check out the expansion tank overflow, that vents into the left side of the frame.
                                        The black shniz and a load of water/coolant came out. It’s still spewing out steam when I heat it!
                                        It’s obvious it’s blocked up at some time, but I dread to think of the damage that could happen over time! It goes right down to the 1&1/2 inch main tube that ties the frame together…
                                        There’s no way I’m using the fuxin frame as an overflow again! 18 inches of rubber pipe will be my next ‘upgrade’! 😉
                                          I found the DTR frame to be of a high quality steel and it was very resistant to rot.
                                          My ETX frame on the other hand...Aprilia are usually shit hot when it comes to the quality of their metal, but my frame is in a really bad state!
