  3. Seized Engine
Seized Engine
23 Posts 5 Posters 10.3k Views 1 Watching
  • MadGyverM MadGyver
    @GiannisT Hey bud,if you want parts get them from Yamaha Nikolakopoulos,they helped me a lot with my rebuild and get me everything, Even the most weird parts that I needed,it was a very worn abused bike.
    G Offline
    G Offline
    GiannisT
    @MadGyver my guy! you just made my life a whoooole lot easier. Na sai kala!
    • MadGyverM Offline
      MadGyverM Offline
      @GiannisT No worries bud,if I can help you with parts in Greece or knowledge I will tell you.
      Τίποτα φίλε.
      • G Offline
        G Offline
        GiannisT
        wrote on last edited by GiannisT
        Well i finally had the time to dive into it yesterday. pulled the engine out (which was a much bigger pain than anticipated) and dove into the top end. Needless to say, this is going to be a tricky one. Theres a huge chunk missing from the left side of my piston, plenty of coolant in the bottom end and the connecting rod is rattling left and right like a mf. Also it appears a metal headgasket was used(?). Since i wasnt mentally prepared to dive into the bottom end and fully rebuild this thing I am in grave need of all the help and advice i can get. Cheers
        (also ive been trying to upload/link pictures and a video for like 20' now and i cant seem to figure it out)
        • G GiannisT
          @GiannisT
          Hey bud! Metal head gasket is standard. Con rod side to side movement is normal, they are never fixed ‘in place’. It’s purely the up and down play you don’t want. It would of been making a knocking noise before if it was bad.
          I’d get someone with previous experience to have a look at the crank and bearings. If they’re ok just flush out the crank case and rebore and new piston that puppy!…
          Host the pics on Imgur then copy the link.
          On the toolbar (3rd from the SORRY! right) there’s an oblong box with what looks like a mountain with a moon In it. Click on that and paste your link in…
          G 1 Reply Last reply
          • G GiannisT
            @GiannisT If you do end up having to split the crankcases, here's the link to the crankcase splitter/crankshaft puller combo I used, these are made in the same factory as the "Tusk" branded version sold by Rocky Mountain ATVMC in the US but a lot cheaper:
            https://uk.vevor.com/crankcase-splitter-separator-c_11501/crank-case-splitter-separator-puller-installer-automotive-dirt-bike-supplies-p_010929606602?adp=gmc&utm_source=google&utm_medium=cpc&utm_id=20497631423&utm_term=&gad_source=1&gclid=CjwKCAiAlJKuBhAdEiwAnZb7lWFwnMSlDdb5uSzPdY8J-nY9RNRX31UW8116ea7LeXDXBSEerq6P2hoCUrIQAvD_BwE
            This is the adapter I had made for pulling the crankshaft back into the left main bearing to avoid transmitting a side load through the bearing (which will shorten its life). I had this made up at a local machine shop, you can see how it works, also check out the comments on this YouTube vid, lots of people saying the same thing:
            https://www.youtube.com/watch?v=p0LK30KVWJg&t=1s
              @GiannisT
              G Offline
              G Offline
              GiannisT
              @SpookDog some side movement may be normal but i can’t possibly believe what im looking at is okay. Give this a look and give the video a listen: alt text
              • G GiannisT
                @GiannisT
                Bud! Do it without the piston on. It does look excessive but the piston noise and camera wobble doesn’t help…
                • MadGyverM Offline
                  MadGyverM Offline
                  Suggestion.
                  If you have never open an engine before see some extended video's rebuilding DTR engine. Take notes,ask and have a lot of patience. It's an engine that tou lay hands firts time.
                  I've opened my engine 6 times during the rebuild and had manufactured all the tools at the 3rd time. Had seen many video's.and read almost all this forum and the old archived one.
                    That engine loos F@CKED lol.
                    The cylinder head is shot, the piston is half missing.
                    The piston is supposed to have float. What people are referring to is some minor "Big End" float on the crank shaft, not the piston float on the gudgeon pin. I highly doubt that engine seized on tickover, looks like piston "Death Ash", indicating that's been running lean for some time. The piston skirt is damaged and therefore it's probably gone into the bottom end.
                      G Offline
                      G Offline
                      GiannisT
                      @Calum how would you go about dealing with this? Is there a smarter/better way of going about it than just tearing the engine down to bolts and going from there? Also while we’re at it, what should be done to the head besides it getting skimmed?
                        @GiannisT The smart thing to do would be to tear it down and inspect/renew where appropriate. There is no shortcuts, one way or the other that engine is coming apart. If the swarf hasn't contaminated the main bearings it'll no doubt have damaged the big end bearing. Anything short cut you do will likely cause further harm and stress to other components causing bigger, more expensive, problems in the long run. That bike didn't die on tickover, going by the extent of the damage to that piston/head.
                        The head needs throwing in the bin, it's trashed. You might be able to get a tuner to alter the squishband and remove the detonation/debris marks from the head, but as it stands it's a glorified paper weight.
                        The problem with running damaged heads such as that, is that it encourages detonation, even if the jetting appears to be correct. In other words, it's just a shortcut to a blown engine, doubly frustrating when it's freshly built.
                        My advice, don't scrimp on critical components, it'll just come back to bite you.
                        You could spit the cases and inspect the components for wear. If all is in order then you may not need to renew (although I would anyway).
                        You could just inspect it in situ and see if the float is okay and if the big end bearing is damaged by checking for play. No way to tell about the mains or crankcase seals without tearing it apart. If debris has contaminated the seals then it will never idle/run right.
