  3. Exhaust
  4. exhaust expansion chamber bolted
14 Posts 5 Posters 3.4k Views
  • E Offline
    E Offline
    erion1
    creating another post about my exhaust pipe as i see that i have a maybe rare pipe and i wanna know if this model has a resriction in the middle as it can be disassembled in 2 pieces and i can remove it here is a pic of it
    https://imgur.com/gallery/tP4PBBE
    i never saw an exhaust that is put together in the middle like that
      Yeah that's interesting, I've never seen one like that before...
      • E erion1
        @erion1
        Looks like a standard pipe (especially with the heat shield’s) that someone has already cut it in half, then welded two flanges on to bolt it back together…
        I’m not sure why they didn’t just weld it back for aesthetics…
          HOTSHOT IIIH Online
          HOTSHOT IIIH Online
          @erion1 @Calum I've seen DTRs for sale described as "imported from Switzerland" before with a front pipe like that. I think it separates because it has a catalytic convertor, and the extra heat shield is something to do with their safety rules for new vehicles.
          There is a very interesting Jeremy Clarkson's Motorworld all about Switzerland, it's a very beautiful country but you're not allowed to do anything. In the 90s a brand new Kawasaki ZZ-R1100 was the fastest production motorcycle you could buy except Swiss spec ones were restricted to 70bhp. Also the owners' manual that came with my 1st French import DTR instructed the new owner to change gear between 7 and 9000rpm for maximum riding enjoyment, unless you live in Switzerland, in which case you should change gear at 4000rpm.
          https://www.youtube.com/watch?v=hs9-6d6gYMU
          CalumC E S Stevie WonderS 4 Replies Last reply
            @HOTSHOT-III 🤣 Shut Up 😛 That's hilarious.
              E Offline
              E Offline
              erion1
              @HOTSHOT-III it was imported from swiss here to kosovo i could may be the 2nd owner of this bike from factory
              but im trying to get more info about this type of pipe, and i don't think its some type of restriction as the bike is a 4bl 91 model with unrestricted cdi
              i may open it up to see what is it.
              btw do unrestricted dt's still have restrictions in exhaust
              • E erion1
                HOTSHOT IIIH Online
                HOTSHOT IIIH Online
                @erion1 Some DTR stock front pipes have a washer in the header pipe and some don't, if yours has one you'll see it where the header pipe meets the cylinder.
                If you want to keep the stock pipe try and find one marked 3MB from France as in my experience these have no restriction in either the front pipe or silencer.
                E 1 Reply Last reply
                  E Offline
                  E Offline
                  erion1
                  @HOTSHOT-III i dont think it had a washer when i took the bike apart bc i checked it but some have a restriction in middle of the pipe on the widest point, as for the silencer i don't have the original one anymore it has a fake akrapovic 4t exhaust
                    Fountain of knowledge! Swiss have a cat in the exhaust? and the heat shield doubles as a cheese grater!
                    I can vaguely remember the clarkson in swiz thing. Don’t they have a 40mph speed limit, or some such crazy?…
                    Is it them that go crazy doing rally racing every weekend to blow of sauna steam! 😜 …
                    HOTSHOT IIIH E 2 Replies Last reply
                      HOTSHOT IIIH Online
                      HOTSHOT IIIH Online
                      @SpookDog I think Clarkson also made an episode of Motorworld in Iceland where they were hill climbing monster trucks up and down these mounds of volcanic ash.
                      Yes Switzerland is completely anti-car and anti-motorcycle unfortunately, and it's coming here. This new 20mph speed limit in Wales is causing a lot of problems and it's happening in Wimborne in April.
                        Blandford is already 20mm through town. So are parts of Broadstone…
                          E Offline
                          E Offline
                          erion1
                          @SpookDog i dont really know maybe parts were changed at some point, it has unrestricted cdi and no speed limits whatsoever but i will for sure open that sheet up to see what is it for
                            Stevie WonderS Offline
                            Stevie Wonder
                            @HOTSHOT-III Yamaha unwittingly cracking jokes / taking the piss is pretty funny
                            • Stevie WonderS Offline
                              Stevie Wonder
                              If you check the pipe by where your horn is they’ll be a part number, post it on here for some comparisons. It could be a unique part to Swiss models.
