  4. Power valve sound
Power valve sound
4 Posts 3 Posters 1.2k Views
  • VcelickaV
    VcelickaV
    Vcelicka
    Hi guys, my power valve started sounding weird when i turn on the bike. At first it wall a little like nothing but now it sounds like i have small mice factory in there..... Should i be concerned?
    • VcelickaV Vcelicka
      @Vcelicka
      My power valve in the barrel actually started sticking/seizing because I was using inferior 2T oil. It made the servo work overtime!
      I’d undo the centre screw and remove the cable rotor. Then check the servo to see if it sounds better without the load of the power valve on it. If it does try turning the valve by hand and seeing if it’s sticky or not…
      Whatever you do, I would definitely check it out…
      VcelickaV 1 Reply Last reply
        @Vcelicka
        VcelickaV
        VcelickaV
        Vcelicka
        Ok i will try it , thx 🙌
        • Stevie WonderS
          Stevie WonderS
          Stevie Wonder
          Taking the powervalve apart is pretty easy, you’d be surprised how gummed up it can get too. Always worth checking that out
