  4. Bogging
Bogging
13 Posts 3 Posters 2.9k Views
  • VcelickaV Vcelicka
    Yes i check that , and looks fine no oil under it clean.
    @Vcelicka
    Think of anything else that you may of changed or disturbed during the exhaust change. Even left a rag on top of the air box!…
    Failing that I’d start by checking and cleaning the carb, plug and cap…
    It’s a weird one!…
    VcelickaV 1 Reply Last reply
      @Vcelicka Is this pipe used?
      https://www.youtube.com/watch?v=v7u27ITL8vM
      I have had problems before where gunk has got lodged in the exhaust pipe causing the bike to just not run properly. That video gives a good idea of how they cleaned theirs out.
        @Vcelicka
        It’s a weird one!…
        VcelickaV
        VcelickaV
        Vcelicka
        I already cleaned everything
          VcelickaV
          VcelickaV
          Vcelicka
          Its similar
          I will try to decarbonize it . Is there anything dangerous about that process?
            Its similar
            @Vcelicka Probably! But the effect it had on a previous bike was dramatic!
              @Vcelicka
              It was a second hand pipe then? Could be clogged up…
              Don’t explain why your old pipe that was fine before should be running wrong…
              I’d look beyond the pipe…
              PS Is the Athena tailpipe clear? It’s the only thing that’s common to both pipes…
                Also double check the manifold gasket seal. No oil isn’t proof of a leak on such short rides. Put your hand over the tailpipe, it should be ‘hells’ quiet…
                Also, be careful when bumb starting a bike. It can be PITA! 😜 …
                  VcelickaV
                  VcelickaV
                  Vcelicka
                  PITA ?😂 little update i cleaned the pipe , there was a little carbon build up but not much . Now when i rode it up a little hil (10% incline) it did missed put when i WOT and sputter.
                  And the powervalve adjustment leaks oil out of nowhere…
                  Where is the problem now?
                    @Vcelicka
                    PITA= Pain In The Ass…
                    If you have black 2T oil coming out of the power valve servo housing, the orange oil seal probably needs replacing…
                    Unless you have accidentally mucked something up when you were changing over the exhausts, you’re going to have to go back to square one. IE re clean the carb, clean the plug and check the cap and HT lead. Everything that can affect running…
                    Double check the exhaust gasket, try refitting it with some RTV silicon sealant…
                    PS it can sometimes get oily when the bike is running rich or misfiring a lot, in my experience. It’s basically unburnt 2T oil…
                    It’s missing for a reason, you just have to find the culprit…
                      @Vcelicka
                      VcelickaV
                      VcelickaV
                      Vcelicka
                      Ok i will try everything ……… I will find it 😂🤣
