  3. Welcome New Owners!
  4. Hello forum, I'm new here, I would appreciate the help.
25 Posts 5 Posters 9.9k Views
  • R
    R
    Rallyfinnen
    Sounds like you disconnected the boost bottle on the intake? (YEIS i think Yamaha calls it)
    Did you plug the hole? If so, it should not idle, but would run significantly leaner on WOT, giving more rpm if it was rich before.
    facundo duarteF 1 Reply Last reply
    • R
      R
      Rallyfinnen
      I mean if you did not plug the hole.
      If you remove it and just plug the hole, it should not affect full throttle at all.
      • R Rallyfinnen
        facundo duarteF
        facundo duarteF
        facundo duarte
        @Rallyfinnen Hello friend, it is not the yeis that disconnected. What I disconnected is a black bottle that goes on the side of the frame and is screwed into it. It connects to the rubber that joins the air filter box to the carburetor, I understand that not all models have it.
        • R Rallyfinnen
          facundo duarteF
          facundo duarteF
          facundo duarte
          @Rallyfinnen Continuing with what was said, by giving it more air in this way the bike improved significantly. That's why I doubt and maybe a 210 plane is needed instead of 240. Maybe this is some kind of limitation? What really changes in the previous, more similar models to carry this model with larger aircraft? Or I have a weak spark at high rpm, so with a higher, leaner air ratio, the mixture reaches the rpm it should reach but probably with less power.
          • facundo duarteF facundo duarte
            @facundo-duarte
            Try cleaning your air filter. All you are doing is by-passing the filter and sponge element.
              Go with what @SpookDog said. If you removed the YEIS from the Carb Boot...your carb settings should be okay (perhaps a little lean), since you're not altering the air after the carburettor, merely increasing flow over the carb. If you remove the one on the inlet manifold then yes it'll be a huge air leak, but you didn't....
              So that to me sounds like poor flow through the airbox system. So remove the airbox lid and give it a good clean. Make sure the snorkel isn't obstructed etc.
                yeah, yamaha doesnt recomend cleaning the foam element with petrol, but as long as you dry it out its noy a problem. then lightly oil the foam and sqeeze out any excess in a bit or two of kitchen roll. make sure to clean the rubber 'snorkel' and any dirt/dust from the top of the airbox...
                brake clutch cleaner works well too...
                • facundo duarteF
                  facundo duarteF
                  facundo duarte
                  @SpookDog @Calum Thanks again for the suggestions but let's go in parts, Jack said, I made sure the air filter was clean, then maybe I expressed myself wrong or it was the translator's fault, but I repeat, I didn't remove the yeis. I removed the black bottle that is bolted to the frame on the side and fits into the rubber that connects the air filter housing to the carburetor. That is, imagine the air entering in excess when opening that inlet and very little through the air filter box. The logical thing would be to think that it would work worse but it was when the bike worked better at least in wot and it did not have the damn failure despite the large excessive air intake, which makes me think that perhaps I still have an electrical fault that I have not yet detected and that would make a weak spark at high revolutions that is not powerful enough to burn the fuel in wot. I even tried with everything connected without the snorkel and although it improved it was still a little rich so imagine.
                    @facundo-duarte Yes that's correct.
                    On later models Yamaha fitted two YEIS bottles.
                    One to the inlet manifold, and then one to the carburetor boot. You've removed the one fitted to the carburetor boot.
                    It sounds like not enough air flow to me.
                    If you remove the air filter/carburetor boot altogether you can see if your problem goes away and that tells you it's the airbox.
                    • facundo duarteF
                      facundo duarteF
                      facundo duarte
                      @Calum Oh well, I didn't know he also had the same name as the other one, good to know. On the other hand, if the motorcycle is original and not modified, why do you suggest that the problem could be in the airbox if it is in good condition? Or did I misunderstand what you mean?
                        Do you have the Snorkel fitted? Is there anything obstructing the top of the airbox?
                        I think this based off what you've told me. Sounds like giving it more air has resulted in night and day performance. Ergo, it's intake related.
                          facundo duarteF
                          facundo duarteF
                          facundo duarte
                          @Calum That's right, I already tried with and without a snorkel. without it works better in wot, although it still needed a little more, that's why I tried removing the yeis that is screwed to the frame. If we look at the problem with the naked eye it would suggest that I have a main jet that is too rich, however I checked its sizes including the pilot and they are fine, they correspond to the DTR model.
                          • facundo duarteF
                            facundo duarteF
                            facundo duarte
                            wrote on last edited by facundo duarte
                            #22
                            @Calum Now that I look at it I don't know if it has anything to do with it, but I have a four-wire connector disconnected near the water tank in the back, apart from the one for the lights and indicators. I read that it is for the neutral relay but it doesn't have it, I have to attach a cable or something. Could it have something to do with that?
                              I'd leave the jetting alone, Yamaha spent a lot of R&D in the jetting.
                              You should be running the bike with the snorkel in as it's adverse to performance to remove it.
                              Make sure that the carb boot is clear of any debris.
                              • facundo duarteF
                                facundo duarteF
                                facundo duarte
                                #24
                                I agree @Calum , I will let you know if there is any news. Did you see the message above about the neutral relay?
                                  @facundo-duarte
                                  There are loads of unused block connectors all over my 1988. Just cause it’s there doesn’t mean it HAS to be used…
                                  Your jetting is perfect for a late model Mikuni 28mm flatslide…
                                  I’d try removing the side of the air box yourself (don’t take somebody else’s word on it) and remove the the foam element. They fall apart over time, especially the aftermarket ones….
                                  They need cleaning with solvent, or petrol but make sure it’s proper dry. Then you have to wet it with oil and squeeze out all the excess…
