  4. Bike seems to leak coolant from kickstand ??
33 Posts 5 Posters 6.2k Views
  • mbmO8M
    mbmO8M
    mbmO8
    wrote on last edited by mbmO8
    Thank you very much, that’s me swapped over the cap for a spare one I had and I’ll get back to you after my ride today
    P.S. the head gasket is all on the right way as I could just see the “up”
      Good, sounds like you've ruled out those two main issues, so it'll be something simple. Radiator cap is a usual suspect.
      • mbmO8M
        mbmO8M
        mbmO8
        I’ve tried another cap ( an old one that came with the bike as the bike came with 2 boxes of parts) and it seams to be worse so I think that shows both caps are bad and the og one wasn’t as bad
        Thank you very much
        • mbmO8M
          mbmO8M
          mbmO8
          Hi again, so after trying a new cap it hasn’t seamed to fix it but I am 95% sure I found the source of the leak (see image ) is this hole ment to be used as an overflow and does anyone have a full Coolant system diagram
          • mbmO8M
            mbmO8M
            mbmO8
            Update.
            so i have a reason to believe that its my water pump that has failed, does anyone know how to test the water pump before removing it ?
              Why would it be the waterpump? That's on the other side of the engine/bike. It's no where near the stand?
              Do you mean you think it's getting hot and overflowing because the waterpump doesn't work???
              • mbmO8M
                mbmO8M
                mbmO8
                Been working on it all day and we have since found it wasn’t the water pump still trying to figure it out haha
                • S
                  Have you checked the thermostat?
                  Is the coolant in the radiator staying at the same level, or are you constantly topping it up?
                  The only reason for the expansion tank to be full and overflowing is if the head gasket has blown and is pressuring the coolant system, which results in loss of coolant through the expansion tank.
                  P.S. yes the expansion tank is connected to that part of the frame by a small rubber tube. it lives up behind the side panel above the rear wheel. there's a min & max level about halfway up the tank. Check it out to see if it's full to the top...
                  • mbmO8M
                    mbmO8M
                    mbmO8
                    @SpookDog would this not contaminate the coolant as I have never seen anything in the coolant and always drains perfectly clear
                    • mbmO8M mbmO8
                      @mbmO8
                      Sorry for late reply.
                      It’s since you did the top end build I’m thinking about, not before.
                      It can take a while for sludge to build up.
                      Is it loosing coolant from the radiator? Check the level …
                      • mbmO8M
                        mbmO8M
                        mbmO8
                        Yes it’s loosing cooling from the radiator quite a bit
                        • mbmO8M mbmO8
                          @mbmO8
                          Head’s still leaking bud. It’s probably best to replace the base/barrel gasket as well.
                          Myself, I remove the studs from the barrel an lap the top in with a square of plate glass and some 240-ish wet and dry sand paper. Then do the same with the cylinder head. Just to remove the crap.
                          Doing up the head nuts really needs a little 1/4 in drive torque wrench to get it right. I do it in three stages…
                          I know that it’s no consolation but I’ve just had to put a newly rebored barrel and head on and had to go through all the fuxin hassle of it myself 🫤 …
                          • mbmO8M
                            mbmO8M
                            mbmO8
                            I replaced the head gasket and got the head machined flat and that was all good … for about 500 miles . Now it’s started doing it again but this time the temps arnt shooting up
                            • mbmO8M mbmO8
                              @mbmO8 Just checking, you used a genuine/Athena/Vertex head gasket? Not a knock off. And the head gasket was installed the right way up?
                              • mbmO8M
                                mbmO8M
                                mbmO8
                                Yep right way up and Athena from PJME.co.uk
                                  Did you torque the head up in a star pattern evenly?
                                  Did you retorque after a few heat cycles?
                                  You're running standard barrel yes, as the Athena kits need o rings for the spark plugs.
                                  • mbmO8M
                                    mbmO8M
                                    mbmO8
                                    Standard barrel and derestricted but factory head and I torqued them to the best of my ability due to the tight space some of the bolts are in
                                      Yeah it's a nightmare trying to get the torque wrench in, can help to drop the front engine mount bolt gives you a bit of wiggle room.
                                      Just go over the bolts and make sure none of them have rattled loose again.
                                      Often these things come from a very simple place. So just double/triple check all coolant hoses/unions etc.
                                      • mbmO8M
                                        mbmO8M
                                        mbmO8
                                        I had a spare head gasket from the gasket set I got from yambits I know it’s not Athena but I’ll order one up and it’s on now and seaming to be fine thank you lot
                                        • mbmO8M
                                          mbmO8M
                                          mbmO8
                                          And that didn’t last long …
                                          The gasket has started leaking already after maybe 80 miles. Going to order an Athena one later tonight and I was wondering if it would be worth skimming my head and barrel mating surfaces?
