  3. Framework
  4. Can anyone tell me what year this frame is?
4 Posts 3 Posters 1.0k Views
  • S
    It’s starting with JYA4BL
    I don’t know if it’s a Dtr or a DtrE
    Ta!…
    • S
      No body know when 4BL,s were about?
        @SpookDog My French '93 frame/engine numbers started 4BL (no JYA prefix) even though it had 3NC electrics, I think 4BL might just mean it was originally sold in France.
        Re DTR or DTRe, a later DTRe will have different spigots for the fuel tank rubbers and a mount for the ignition switch on the frame just behind the headstock as they had that funny shaped top yoke with a hole for the steering lock pin to engage in. You can also tell an old shape DTRE frame from a DTR as it will have an extra mounting lug for the starter solenoid just below the battery, and I think mine also had some other mounting lugs on the very bottom of the engine cradle for a small cover to protect the starter motor.
        How's your suspension linkage job going?
        • D
          dan28
          If you hpi check it using the frame number it will tell you the reg. That's assuming it finds it
