  4. Airbox holder guide foam has seen better days
7 Posts 3 Posters 351 Views
  • D
    DTGREENLANER
    Hello
    Went to do a service on my DT125RE and when going to replace air filter the Airbox holder guide foam material is all falling apart
    https://ibb.co/MyQXNL8w
    https://ibb.co/84PwwMgf
    https://ibb.co/yFJsF8Vs
    Having a look online fowlers want £55!
    Part number 3BN-14459-00
    Has anyone ran without the foam on that part and just relied on the actual air box filter?
    Or Should I just remove any loose bits and keep using it or is it really worth replacing ?
    Many thanks
      You must be able to just buy some double sided foam tape somewhere and just repply.
        DTGREENLANER
        That’s a good idea
        Thank you I’ll try sorting something
        • D DTGREENLANER
          That’s a good idea
          @DTGREENLANER Get some 5mm air filter foam off eBay, clean the holder thoroughly and glue it on using Seal-All, a petrol and oil resistant glue. This is very important, if you run the bike without this the engine will suck dirt. It's also worth applying a dribble of foam filter oil right around it before sliding it back into the airbox with a fresh filter installed.
          https://www.ebay.co.uk/itm/365607220379?_skw=air+filter+foam+sheet+5mm&itmmeta=01KXEHQNAYY94YVPA0ZCWEDJWT&hash=item551fe3749b:g:bw0AAOSwvgZoJ56X&itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xBJIt2fFtFYVz7npvy9%2FdRi6S7mEgUJZasERX59eCBKfXenkOvpapeRTvdBtNGUKUfiPY4fEK4pf%2B9FZEvfYbBUON3xdL3tnhWs58zVRQNZ7pceGI5BgLatkYMECyxPveg5pYDIaV21EePCl7Cqfvwvk3ioK5viwwH2Yz8sIBO23aXzUAkNNyDVUNCXMZc3LzjGdqxuqVXOAKppI%2BXdoEEGNlsakeXqsPKIdfDmz%2BI2T5pOUti5Eev1OACioI8km0yJRYiIVkU2JROBBc1g6SRJx%2FMTcKF3eHF9UzWNeU7y5%2BvMJ4u3qBNGNE1dBrHcjSI%3D|tkp%3ABk9SR-DV3tHrZw
          https://www.repairproducts.co.uk/product/seal-all-gas-oil-resistant-adhesive/
            DTGREENLANER
            Ok cheers mate for that, I’ve ordered what you recommended
            Cheers
            • D
              DTGREENLANER
              https://ibb.co/Szv34sY
              Got round to doing it today
              Cheers for your helps
              • D DTGREENLANER
                @DTGREENLANER Nice job, that looks ace!!
