Hello Everyone! Planning to buy a DTR125
Hello,
Oh okay that sounds good.
There isn't exactly common problems with these bikes, if it's well maintained then they really do go on forever.
At that sort of mileage, and if it truly has never been opened, I'd expect the little end bearing to have worn excessively and rings need replacing. This will be tellable through a rattly top end from the small bearing and piston slap.
But again it's all down to how it's been treated.
The clutch baskets wear out over time so you can expect noise coming from the clutch area.
Other things can be like the bushes on the powervalves can be known go wear out. Again this will be proceeded by rattling noise from the top end. If the bushes are left to wear out so much they can have quite dire consequences.
All of these are minor really and shouldn't take any time all to address.
Look forward to hearing more about your endeavours, they're brilliant little machines when maintained properly.
Hello! Well I bought it! It pulls good, starts cold in just a few turns of a starter. Bike does not look 30 years old at all. Everything on the bike works, including the YPVS. Sounds coming from the engine sound normal to me, i will attach a cold start clip of the engine sound below. Previous owner had it for normal cruising on the street to the bar and so on.
I do wonder, there is different information, does the cylinder have a nikasil coating? If so, all the bike needs is a new piston thats it?
What is some general maintenance I should do before riding it? How can i refresh the YPVS so it keeps working, same with autolube?
https://www.youtube.com/shorts/LkBWrjSWNoc
https://www.youtube.com/watch?v=NDzEm13lvdkThanks for the help!
Congrats, looks nice! Cylinder has a iron sleeve, and can be rebored. Autolube might need adjusting with time, and replacing seals if it leaks. Try finding the repair manual online (Yamaha or Haynes), can be found on Facebook groups etc. Videos not available.
@Rallyfinnen thanks!
What do you think about the sounds coming from the engine? Does it sound okay so it would last till the end of the season so I can rebore and change the piston in the winter? I want to drive it a bit, is my first proper bike, I’ve only ridden 50cc mopeds till now, time for a step up after 10 years od 50cc. Wish I would’ve bought this 10 years ago
Like I said, videos did not work for me..
@Rallyfinnen oh sorry, just noticed they were set to private. They should work now
Oh wow, what a lovely lovely DTR you have there. Please please please keep that original and no silly mods. That is a little time capsule there.
Sounds good listening to it on my phone.
If it pulls well and starts easy then in all likelihood it's a good motor congratulations
@Calum Thank you! Ofcourse im keeping it original, I already removed Agip and Akrapovic stickers, in all about that OEM look. Cant really ride it yet, getting my license this week.
Thanks for the help on the sound, I really have no idea how a proper two stroke should sound, its totally different to the 50cc Tomos mopeds I’ve been riding with.
