  3. Welcome New Owners!
  4. Hello Everyone! Planning to buy a DTR125
33 Posts 4 Posters 2.1k Views
    Oh wow, what a lovely lovely DTR you have there. Please please please keep that original and no silly mods. That is a little time capsule there.
    Sounds good listening to it on my phone.
    If it pulls well and starts easy then in all likelihood it's a good motor congratulations 🎉
    V
    V
    Vuteng
    @Calum Thank you! Ofcourse im keeping it original, I already removed Agip and Akrapovic stickers, in all about that OEM look. Cant really ride it yet, getting my license this week.
    Thanks for the help on the sound, I really have no idea how a proper two stroke should sound, its totally different to the 50cc Tomos mopeds I’ve been riding with.
      Such an iconic livery set on there as well. Looks great 😊
      • V Vuteng
        @Vuteng +1 for keeping this bike original, it looks great and the motor sounds good to me. I'd definitely enjoy riding it for the rest of the summer before taking on any serious work. In one of the vids it does sound like the rubber snorkel could be missing from the airbox intake, if you're somewhere in the EU the easiest way to get one is probably to just get a complete airbox from a French or German breaker which have plenty of DTRs. This model also shares the CDI unit and YPVS servo (both marked 3MB) with the KTM LC2 125 which sold well in Europe so if you want a spare CDI unit/servo that might be the best way to find these.
        Looks like you have an OEM clutch cable, this and (especially) the throttle cable are best kept original as the throttle cable splitter has a mechanism that balances the carb and Autolube at all throttle openings. These are still available new and worth every penny.
        This model I think had a dark blue seat when new (same colour as the frame/fork gaiters), probably available from bikerpartshop in Portugal:
        https://www.bikerpartshop.com/en/166-dtr-50-125-200
        Definitely retain the Autolube, and get a Haynes or Yamaha manual which explains how to bleed and adjust the oil pump. It's also well worth reconditioning it with a kit from Yambits. They used to sell a clear oil line kit but I can't find it, car windscreen washer hose works just as well. Here's a list of other bits to order at the same time, air filter elements are as good as OEM but half the price (get 3 or 4 so you can keep cleaning and re-oiling them and store them ready to change in a plastic bag, this is the easiest way to look after your engine), cable oiler (essential):
        https://yambits.co.uk/dt125re-air-filter-p-9241.html
        https://yambits.co.uk/dt125re-airbox-snorkel-genuine-p-230082.html
        https://yambits.co.uk/dt125re-oil-pump-repair-kit-1989-1995-p-218588.html
        https://yambits.co.uk/dt125re-oil-pump-oil-line-elbow-p-65302.html
        https://yambits.co.uk/dt125re-cable-lubricating-tool-p-46571.html
        Also here are a couple of things I like to do to any DTR; a full suspension linkage strip including making sure the troublesome relay arm bolt never seizes again, and making your own YPVS cables from MTB gear cables:
        https://dt125r.co.uk/post/28245
        https://dt125r.co.uk/post/28693
        • V
          V
          Vuteng
          wrote on last edited by Vuteng
          @HOTSHOT-III Thank you very much for the information! I was just in the garage taking stuff apart and I took a look at the airfilter. The snorkel and everything is there but the foam on the air filter bracket is all fallen apart so I cleaned everything and blew out the airbox. I think this foam around the bracket is needed so it seals correct? Is there a way to reaply it or should I find a replacement one? Pic below to explain what I mean
          Also I noticed that the red oil light never turns on, from what I’ve read in the manuals it should glow red while idling in neutral, correct? The pump is working as the bike is smoking
          Seat was pink from what I found on the web and I really love the look with the pink seat so i will try to find that
          • V Vuteng
            @Vuteng No worries. You may be right about the pink seat, it's hard to keep track sometimes lol.
            The oil light should illuminate with the neutral light, it might just be a bulb.
            The air filter holder can be repaired with new foam. Get some 5mm air filter foam off eBay, clean the holder thoroughly and glue it on using Seal-All, a petrol and oil resistant glue. This is very important, if you run the bike without this the engine will suck dirt. It's also worth applying a dribble of foam filter oil right around it before sliding it back into the airbox with a fresh filter installed.
            https://www.ebay.co.uk/itm/365607220379?_skw=air+filter+foam+sheet+5mm&itmmeta=01KXEHQNAYY94YVPA0ZCWEDJWT&hash=item551fe3749b:g:bw0AAOSwvgZoJ56X&itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xBJIt2fFtFYVz7npvy9%2FdRi6S7mEgUJZasERX59eCBKfXenkOvpapeRTvdBtNGUKUfiPY4fEK4pf%2B9FZEvfYbBUON3xdL3tnhWs58zVRQNZ7pceGI5BgLatkYMECyxPveg5pYDIaV21EePCl7Cqfvwvk3ioK5viwwH2Yz8sIBO23aXzUAkNNyDVUNCXMZc3LzjGdqxuqVXOAKppI%2BXdoEEGNlsakeXqsPKIdfDmz%2BI2T5pOUti5Eev1OACioI8km0yJRYiIVkU2JROBBc1g6SRJx%2FMTcKF3eHF9UzWNeU7y5%2BvMJ4u3qBNGNE1dBrHcjSI%3D|tkp%3ABk9SR-DV3tHrZw
            https://www.repairproducts.co.uk/product/seal-all-gas-oil-resistant-adhesive/
            V 1 Reply Last reply
              V
              V
              Vuteng
              @HOTSHOT-III Today I redid the foam, used some air filter foam I found and epoxy glued it + new air filter all oiled up. I tested the kickstand switch and it works but the oil light is not working. Will dismantle the tacho tomorrow. I looked at it today, i just remove the two pins underneath and it comes apart?
              • V Vuteng
                @Vuteng Yes that's right, just remove the two "R" clips under the tacho. All the bulb holders are rubber and just pull out of the tacho.
                Great to hear you repaired the air filter holder!
                  V
                  V
                  Vuteng
                  @HOTSHOT-III Today i took the cluster apart, bulb is okay. So I followed the wires of the oil level sensor and it's unplugged. I suspect I have to take off the tank to reconnect it? I guess it's disconnected because it is not working.
                  • V Vuteng
                    @Vuteng The previous owner may have just forgotten to reconnect it for some reason, if that fixes it then great. Connector is underneath the fuel tank as you say.
                    • V
                      V
                      Vuteng
                      I have registered the bike yesterday, already covered 100km. Love it! But what I've noticed dtarted to bother me, the clutch is veeery hard, so I would like to lube up the cable. What is the procedure to remove the cable from the bike and how to adjust it correctly?
                      Also I noticed humming in 6th gear if I shift into 6th at 70kmh. If i go 80+ its okay. That is normal?
                      Another thing I noticed, the bike falls on its face at 8k rpm, is it a CDI restriction or something else?
                      Thanks for the help!
                        Clutch could be stiff for many reasons. I run uprated clutch springs on my DTR so it is stiffer.
                        The clutch cable comes off very simply, just slacken the adjuster nuts on the clutch arm on the engine, then remove the cable from the engine. Route it through the frame and disconnect from the clutch perch.
                        You can then run some lubricant through the cable. I suspect though it'll be the clutch springs.
                        If the bike is falling flat on its face at 8k, then I'd initially say Powervalve.
                        Easy way to tell. Take the exhaust off, switch the ignition on and off (you'll hear the servo do the cleaning cycle). Once the powervalve turns flush with the exhaust port, switch the ignition off. Disconnect the powervalve servo from the main loom and ride the bike.
                        The bike should lose all bottom end, so basically gutless below 6k, but should rev to the limiter.
                        If this is the case, you've identified it's the powervalve. If this is not the case, then you know the problem lies elsewhere.
                          V
                          V
                          Vuteng
                          @Calum Thank you for the info, just ordered adjustable clutch and brake levers as they are very far away and I dont have small hands. Regarding the 8k problem, I tried it more today and I wouldnt say it completely stops, but It feel smore like a soft limiter, it just stops revving. I've read it can be a CDI limiter, how can I know for sure?
                            Did you try the powervalve trick I just told you about?
                            I know that the restrictions on the UK models differ from overseas models, so I am not familiar with what restrictions there are on other regions.
                            Either way, grabbing yourself a Zeeltronic ignition system will make all of these problems disappear and you'll gain a noticeable midrange boost.
                              V
                              V
                              Vuteng
                              #22
                              @Calum Havent tried the powervalve trick you just told me about, will try in the weekend. So when I unplug the powervalve, to what rpm should the bike spin? Same 8k but without bottom end or higher?
                              How much is the Zeeltronic ignition system?
                                It should rev to the redline.
                                Depends on where you get your Zeel from, I paid £200 for mine, but that was like 12+ years ago.
                                • V
                                  V
                                  Vuteng
                                  Hello!
                                  Enjoying the bike alot! Installed adjustable levers, changed motor oil, bike works great! But what I’ve noticed, the days it is hotter (above 30c). The temperature starts climbing quick when standing at red lights(3-4 minutes of sitting at one place), if I drive its okay, needle sits just under half. I have mostly city driving, how do you guys battle this issue, possible to install a fan or a coolant sevice should help enough?
                                    DTRs do seem to run very hot in my experience. Always have, wouldn't worry about it.
                                    My Aprilia RS usually sits around the 60 degree mark, I run a Vapor Trail Tech unit on my DTRE and it's ready 110 before!
                                    To combat this, I removed the thermostat and now it sits around the 60-70 mark, just note you do really need to be careful when warming them up to ensure you don't cold-seize the engine.
                                    • V
                                      V
                                      Vuteng
                                      Ah okay, i plan to refurbish the cooling system anyway. So it is better to remove the thermostat if I have mostly city driving? I only start puhsing the bike a bit more when i see the needle move
                                        Well the best thing to do is to check to ensure that the thermostat is working correctly. You can remove it and place it into a sauce pan and check to see if it correctly opens at the right temperature when left to boil.
                                        If your daily commuting the bike, then leaving the thermostat in is advisable. Yamaha know what they're doing.
                                        If you start tuning the bike and pushing it beyond its original specifications, then you may want to consider removing it.
                                        The thermostat isn't just there to aid heating up of the engine, it also has a role in providing pressure in the cylinder head to avoid pocket stagnation of gases. So it's actually important it's fitted.
                                        I just noted that these engines do run warm and removing the thermostat allowed my bike to run at a more consistent temperature when under load.
                                        • V
                                          V
                                          Vuteng
                                          #28
                                          Hey again!
                                          Did a coolant flush, looks like it holds temperature more stable now, it came out dark and brown.
                                          Also continued chasing the 8k rpm limit issue, today I took apart the YPSV pulley and looked at the dot on the shaft marking, looks like it is in the right position? Below i attached two videos, one showing how far i can manually move the shaft left and right and the other one shows how much the servo moves the valve, to me it looks like it does not move the valve that much? Havent taken off the exhaust as I have not yet received the exhaust gasket and Im on the bike everyday so I dont want to have downtime.
                                          https://www.youtube.com/shorts/MiziIZu_GQk
                                          https://www.youtube.com/shorts/Z6HQNFDRNd8
                                          Covered 1100km so far, changed the chain guide, rear tube blew out, 3D printed the front disc guard, changed the seat from black to pink 🙂
