  4. No power from battery
6 Posts 2 Posters 2.0k Views
  • LJK_hunterL Offline
    LJK_hunterL Offline
    LJK_hunter
    My bike was idling while putting my gear on then just cut out, all lights on the clocks went out too. Used the kick start and it started again but the lights flicker as if its only running off the generator? I checked the battery with a multi-meter and it is still charged but the voltage doesn't increase when the bike is held at high revs.
      Fuse bud
        LJK_hunterL Offline
        LJK_hunter
        where is the fuse located? I looked around the battery but couldn't find it.
        • LJK_hunterL LJK_hunter
          @LJK_hunter It's attatched to the battery box
            LJK_hunterL Offline
            LJK_hunter
            I've had another look and still cant find one, but from looking in the haynes wiring diagrams there is no fuse on the DTRE and X models?
              Yeah there is, it's on the battery box just below the rear brake master cylinder.
