  3. Bottom End
  4. Gearbox Oil Vanished!! 😂
Scheduled Pinned Locked Moved Bottom End
11 Posts 6 Posters 4.9k Views
  • Louis-DT-WRL Offline
    Have you removed the drain plug and measured it?
    Could be leaking into the crank housing
    • MightymanM Offline
      MightymanM Offline
      +1 definitely measure it as I've found the oil sight glass is hit or miss at times.
      • ZrakoZ Offline
        ZrakoZ Offline
        Zrako
        wrote on last edited by Zrako
        I have like 900+ ml in the bottom end and still have to tilt it towards right to see the level . Lots of oil is in the gearbox too . Haynes refer to 800ml after rebuild but still not enough for me. Tried to warm up engine and let it sit straight , tried to check after not running few days - same results - below inspection glass...
        Btw. - no leaks and coolant is clear too.
        1979 Jawa Mustang 50
        2003 Gilera DNA 125 R.I.P
        2015 Keeway TX 125 SM
        2006 Yamaha DT 125 X
        • F Offline
          F Offline
          When i built my bike back up i put 850ml as per the manual. Took it for MOT and when i got home it had spat a loud of it out of the breather! I drained a fair bit out after that. Reads in the middle of the sight glass now
            Literally says 750ml on the clutch cover...
            Louis-DT-WRL F 2 Replies Last reply
              @Calum you're correct 900 is way too much
              • ZrakoZ Offline
                ZrakoZ Offline
                Zrako
                Lol I know that 900 is too much . But dont want to fry new clutch , where is all the oil ?
                • ZrakoZ Zrako
                  @Zrako roo much oil can be worse than not enough though
                    When you run too much oil you effectively allow the engine to whip it up, causing bubbles to form. This reduces the oils effectiveness greatly. Therefore, too much oil is just as bad as too little.
                      F Offline
                      F Offline
                      @Calum I did whatever it said on the cover, couldn't remember off the top of my head
