  4. Rev limiter
Rev limiter
23 Posts 4 Posters 17.7k Views 1 Watching
  • D DevonDtr
    Doing this tomorrow anyways, but I want to make double sure as every site and Google search says different. So I snip green/black wire on speedo side, and simply earth it, ie with radiator bolt.. thanks for all the help btw
    Biker_123B
    Biker_123B
    Biker_123
    @DevonDtr Yip that's pretty much it but as Calum pointed out make sure that the paint isn't to thick on the area your earthing the wire to as it might not earth properly so just make sure you get a good contact on the frame 🙂 .
    Every problem has a solution
      To be 100% earth it to the negative terminal of the battery
      • D
        DevonDtr
        wrote on last edited by DevonDtr
        Succeeded today, and not much noticeable difference. Its earthed on top radiator bolt
        Biker_123B CalumC 2 Replies Last reply
        • D DevonDtr
          Biker_123B
          Biker_123B
          Biker_123
          @DevonDtr Well done glad it worked out 🙂
          • D DevonDtr
            See I said that mate when I was 17. I then when I got realised what a mistake that was. It should make a massive difference.
            I went from Zeeltronic to stock. And I had to derestrict it. And realised what a difference it makes.
            It should be massively noticeable. Earth it to the battery mate.
            • S
              seandtr
              Can this mod also be done on a 2003 dt125r ?
              • S seandtr
                Biker_123B
                Biker_123B
                Biker_123
                @seandtr I think it's only for the DTRE/DTX models as they have a few more restrictions than the older DTR .
                • S seandtr
                  @seandtr No, you will need to do the other derestrictions.
                  • D
                    DevonDtr
                    As i know nothing of electrics, is a 27 amp wire sufficient... got the 2 wires in a plug connector
                      seandtr
                      @Calum What other ones is there to be done ? I have removed the snorkel , that is all ?
                      • S seandtr
                        @seandtr Snorkel wants to be in mate. That's not a derestriction. Who keeps telling people that!
                        The removal of the snorkel causes air flow issues. Ruins the flow of the air.
                          seandtr
                          @Calum What derestriction will benefit me mate ? So far my bike has reed block spacer and carbon reeds and a dep end can .
                          • S seandtr
                            @seandtr Ignition system, Expansion chamber and 3MB cylinder head.
                            • D
                              DevonDtr
                              So earthed to battery, 2 wires connected with butt connector. Didn't notice any major difference again but to be fair bike needs jetting
                                As said I remember saying the same all those years ago
