  4. Rev limiter
Rev limiter
23 Posts 4 Posters 17.4k Views 1 Watching
  • D
    DevonDtr
    Only asking this as I want to make sure, tanks off, looking at cdi and bunch of wires to side of it. Which wire do I cut it do de restriction, and can I use any old wire to extend it to radiator bolt?
      Help if you remind us of yhe model mate?
      DtRe?
      Green and black wire that goes into the clocks. And its not a rev limiter. It just retards the powervalve which stoos yhe revs climbing.
      • D
        DevonDtr
        Its an 04 dtre, where exactly should I cut the wire etc
          Don't cut the wire, you need to earth it to the frame.
          So give yourself plenty of wire.
          • D
            DevonDtr
            Ok, sadly my mechanical knowledge is zilch, when you say earth it.... sorry for all the questions buts its only way i will learn 🙂
            Biker_123B CalumC 2 Replies Last reply
            • D DevonDtr
              Biker_123B
              Biker_123B
              Biker_123
              @DevonDtr When he says earth it to the frame that means you'll need to join the exposed end of that wire on to the frame, it'll need to touch the frame to earth properly! It's best to try and find a bolt on the frame the wire reaches to and unscrew the bolt enough to put the wire under it and tighten the bolt back down that way it'll help keep the wire in place and it'll also be earthed!
              Every problem has a solution
              • D DevonDtr
                @DevonDtr Yeah that's fine mate. If the paint is thick you might not get the right conductivity.
                • D
                  DevonDtr
                  Doing this tomorrow anyways, but I want to make double sure as every site and Google search says different. So I snip green/black wire on speedo side, and simply earth it, ie with radiator bolt.. thanks for all the help btw
                  Biker_123B 1 Reply Last reply
                  • D DevonDtr
                    Biker_123B
                    Biker_123B
                    Biker_123
                    @DevonDtr Yip that's pretty much it but as Calum pointed out make sure that the paint isn't to thick on the area your earthing the wire to as it might not earth properly so just make sure you get a good contact on the frame 🙂 .
                      To be 100% earth it to the negative terminal of the battery
                      • D
                        DevonDtr
                        wrote on last edited by DevonDtr
                        Succeeded today, and not much noticeable difference. Its earthed on top radiator bolt
                        • D DevonDtr
                          Biker_123B
                          Biker_123B
                          Biker_123
                          @DevonDtr Well done glad it worked out 🙂
                          • D DevonDtr
                            See I said that mate when I was 17. I then when I got realised what a mistake that was. It should make a massive difference.
                            I went from Zeeltronic to stock. And I had to derestrict it. And realised what a difference it makes.
                            It should be massively noticeable. Earth it to the battery mate.
                            • S
                              seandtr
                              Can this mod also be done on a 2003 dt125r ?
                              • S seandtr
                                Biker_123B
                                Biker_123B
                                Biker_123
                                @seandtr I think it's only for the DTRE/DTX models as they have a few more restrictions than the older DTR .
                                • S seandtr
                                  @seandtr No, you will need to do the other derestrictions.
                                  • D
                                    DevonDtr
                                    As i know nothing of electrics, is a 27 amp wire sufficient... got the 2 wires in a plug connector
                                      seandtr
                                      @Calum What other ones is there to be done ? I have removed the snorkel , that is all ?
                                      • S seandtr
                                        @seandtr Snorkel wants to be in mate. That's not a derestriction. Who keeps telling people that!
                                        The removal of the snorkel causes air flow issues. Ruins the flow of the air.
                                          seandtr
                                          @Calum What derestriction will benefit me mate ? So far my bike has reed block spacer and carbon reeds and a dep end can .
