  4. Spark issue
Spark issue
12 Posts 3 Posters 2.0k Views
  • M Offline
    M Offline
    morty
    Morning guys
    Noobie here
    Bought myself a 2006 dt125x fixer upper
    Currently doesn’t run and want to get it running before I strip it to get the frame powder coated
    Issue I have is while holding the start button there’s no spark but as soon as I release the start button there’s a few sparks before the motor stops
    I have purchased a brand new battery for her.
    Neutral light is on and side stand switch checks out ok
    Gonna start testing everything this weekend and run a wire to the starter to bypass the start button and see if she sparks.
    Has anyone come across this before?
    Thanks in advance
    Steve
    • M morty
      Morning guys
      Noobie here
      Thanks in advance
      Steve
      Irongamer727I Offline
      @morty bump start any good?
      M 1 Reply Last reply
        Check the cables between the ignition switch and the loom. If they oxidise it'll cause problems.
        The CDI could be faulty.
        Double check the coil impedance against the manual. Make sure the HT Lead and spark plug is okay.
        Ensure the generator is functioning as intended.
        • Irongamer727I Irongamer727
          M Offline
          M Offline
          morty
          @irongamer727
          No wheels on at the moment
            M Offline
            M Offline
            morty
            @calum said in Spark issue:
            Doing these today 👍
              Check the pickup as well.
              • M Offline
                M Offline
                morty
                Tried running wire to starter first with ignition on and she fires up and runs.
                I’m thinking there must be a short somewhere or a bad connection
                I read something about issues with ignition switch so might start with this
                • M morty
                  @morty I literally said ignition switch.
                  Not necessarily the switch, but the connector block.
                  • M Offline
                    M Offline
                    morty
                    You did 👍
                    There is some oxidation on the connector block
                    I’ll clean up and try again
                    Thanks
                    • M morty
                      You did 👍
                      Thanks
                      @morty Try some electrical contact cleaner.
                      I had to cut the block, mine was beyond saving. So it's bullet crimps at the moment, which is a pity.
                      • M Offline
                        M Offline
                        morty
                        Think I’ve cracked it
                        After cleaning clutch switch connector she starts every time 👍
                        • M morty
                          @morty Ah yeah, see the DTR's don't have that problem because they don't have a clutch switch!
