  3. DTRE
  4. Yamaha dt125re rebuild
92 Posts 13 Posters 35.0k Views 1 Watching
  • B
    B
    BraDT
    Has anyone got a guide on how to bleed my autolube ? Iv had all the oil out and haven’t a clue how to bleed the sysytem ?
    Any help muchly appreciated
    • B BraDT
      @bradt best way is to run premix in your bike while running with the autolube full bleed the lines there will be a rubber blanking cap on the pump pull that off While the bike is running on premix and when the air bubbles stop coming out plug it back up then watch the flow coming from the pump to engine best use clear lines so you can see the air bubbles then when there’s no bubbles your good to switch back to autolube fully
      • B
        B
        BraDT
        #63
        Cheers mate ordered some clear lines
        Bike all ready now, but have noticed a leak from the carb guessing bowl gasket needs replacing
        Auto lube needs bleeding also and she ready for her first start
        First time out the garage in a few months quick wipe down and a polish
        • B BraDT
          @bradt Mean rear tyre. I hope you plan on taking this offroad!
            #65
            @calum (insert generic Australian accent) that’s not a tyre, THIS is a tyre!
            https://imgur.com/a/rSZ5X47
            • B
              B
              BraDT
              Light off-roading yeah as I’m using for work need it really can do without it breaking down!
              Just that leak to sort out now and struggling to locate one for today as need the bike tomorrow 😑 any local to Sheffield and wanna source a spare bowl gasket ?
              • B BraDT
                @bradt Literally go and make one.
                Go to Halfrauds or a MotorWorld and just buy gasket paper.
                • B
                  B
                  BraDT
                  So will try gasket paper as silicone has stopped the leak but still seems like I’m not getting fuel to the spark ? Anything else I need to check ? All carb was cleaned out new filter in there etc getting abit stressed now
                  • B
                    B
                    BraDT
                    This is a lot harder without electric start working so having to bump the bike every time I try and start it
                    • B
                      B
                      BraDT
                      Does anyone know where the black wire (I’m guess an earth) on the coil is meant to go
                      Iv just fitted a new startermotor to the build makes it easier to start and found I have no coil
                      Noticed the black wire with hook was connected to the coil itself should this be earthed to frame or is this right ?
                      • 2
                        2Stroke4Smoke
                        The starter motor has a red wire only which connects to the starter solenoid (this is the square thing with two fuses in it by the battery). There is a black wire with a hook which connects to the neutral switch which is located near to the starter motor at the bottom of the engine casing on the flywheel side. this in turn plugs into the part of the loom which goes into the stator/generator coil via a bullet connector. Hope this helps.
                        • B
                          B
                          BraDT
                          wrote on last edited by BraDT
                          #72
                          @2Stroke4Smoke very helpful went through all wire and found a broken wire replaced and fixed nice bright sparks and fired up
                          Thank you
                          2 1 Reply Last reply
                          • B BraDT
                            Thank you
                            2Stroke4Smoke
                            @bradt Glad you got it sorted 🙂
                            • B
                              B
                              BraDT
                              So last night after during the match I decided to take the bike for a ride out see how everything was , bike felt great really responsive but loud but exhaust needs sorting
                              Come out for work this morning bike fired up felt great work is only 5mile away iv got just round the corner and my red light came on and the bike was steaming pretty bad I coasted it to work and iv lost all my coolant I’m aware this could be down to the head gasket but I’m hoping it may be something else.
                              There was pressure in the radiator when I took the cap off and the expansion bottle cap has stayed on any one know what else to check before I order a head gasket ?
                              Thanks
                              • B
                                B
                                BraDT
                                #75
                                Her she is looking pretty 🤔
                                • B BraDT
                                  Irongamer727I
                                  Irongamer727I
                                  @bradt have you bled the system of air?
                                  • B
                                    B
                                    BraDT
                                    I did but maybe not long enough cannot see where the coolant is coming from it’s just dried all white over the barrel and head
                                    • B BraDT
                                      #78
                                      @bradt coolant doesent dry I’ve had my fair share of leaks on hot engines and never seen it dry
                                      • B
                                        B
                                        BraDT
                                        @declan surely any liquid would dry and leave some kind of substance after touching a hot engine. Iv reckon iv found the culprit there a little house what connect to carbs what isn’t fully on and can see it coming from there but the amount iv lost surely hasn’t come from there I’m unsure tired and frustrated and still gotta rude home on it tonight after work!
                                        • B BraDT
                                          @bradt Be alright, just take a bottle of water with you. Don't open that radiator cap until it's cooled mind you!
