  4. Bearings for Bottom end.
4 Posts 2 Posters 700 Views
    jamesdowning
    I'm rebuilding my engine and changing the existing engine cases because they have a crack in them which lets the oil out. Question - where do i find information on all the engine bearings in the engine? Haynes manual? They are knackered but havent taken them out yet. Thanks.
      Search be your friend:
      https://dt125r.co.uk/topic/14/gearbox-bearings
      PJME Stock the main bearings. They are an odd size and therefore expensive.
      It should also be written on the side of the bearing.
        jamesdowning
        Thanks mate. You know the quantities? The link has the type but not how many of each. Is it 2 balancer shaft bearings and 1 of everything else? Cheers.
          I think it's one of each bud. Think. To be fair once you split the engine it should be obvious. They will be labelled appropriately.
