  4. Project DTZr.....a DT125R love story
80 Posts 14 Posters 23.0k Views 1 Watching
  • MadGyverM MadGyver
    The finished DTZr,it's on the road,I am doing some runnin km's and will go to a friends dyno. 😀
    Passed technical inspection with "flying colors".
    I didn't put the 3ET headlight because it's no good for night,if you want to see and not just others to see you.
    PS.I will shorten a little the front fender.
    zarkotomZ
    zarkotomZ
    zarkotom
    @madgyver Great bike mate, looks almost like a long lost cousin of my DTR!
    Καλησπέρα απο ελλάδα αδερφέ... Αν έχεις facebook μπες στην ομάδα 2T POWER GREECE... Nα ανεβάσεις καμία φώτο να το χαζέψουμε ακόμα παραπάνω...
    MadGyverM 1 Reply Last reply
    • zarkotomZ zarkotom
      MadGyverM
      MadGyverM
      MadGyver
      #22
      Finishing my modification of 80's YZ/RD/DT125 reedcage,to fit the DTZr.
      It is used because it has less pedals,it's shorter and doesn't block the C boost port of the cylinder the.Widened to fit the carb rubber joint,bolt holes relocated and smoothed the angles.
      [alt text
      [alt text
      [alt text
        [alt text
        [alt text
        [alt text
        @MadGyver Looks sick, I was wondering what the motivation behind this was.
        Be interested to know how this goes once it's all done! Keep up the work.
          MadGyverM
          MadGyverM
          MadGyver
          #24
          Time for a little update.I've finished the reed cage modification and will explain why did it.
          I had 2 failures in fiber reed pedals,and you know how difficult is to take out the reed valve.My first set of boyesen dual stage where used but in very good condition,they bent in various places probably because of age but after doing 1000km,the second set was simple fiber pedals and even the adjustment's I did because of bad finish quality,they couldn't handle the tune of the engine at high rpm's.So i went back to basics,searched the yamaha 2 stroke engines with similar specs as my tuned and saw what reed valve they used. RZ350,RD125LC,YZ125(80's models),TZ750 had the same reed valve.
          Purchased everything genuine,made the mod's to fit the DT rubber joint and already had done the widening to the engine cases as future plan.
          I preferred the above setup because of the shorter and wider steel pedals.Shorter pedals handle higher rpm better,wider are more robust,genuine yamaha made in japan quality steel.
          For the long run,I asked a good friend and old timer mechanic in 2 strokes that helped me with his knowledge,if he has ever see failed steel reed pedals especially in Yamaha's.He said the the worst he saw was bent pedals to touch the stoppers from racing engine,never broken,but where genuine.
          PS. Added bonus,this reed cage does not block the c-port in the back of the cylinder and you don't need spacers that are used in the DT reed cage for that reason.
            @MadGyver
            I had no idea that there were metal petals available!...
              markus.wM
              markus.wM
              @MadGyver I believe the reason for changing reed petals from stainless steel to carbon/ GRP was not for fear of them breaking, though it would be catastrophic I think it's very rare. But more due to them suffering from metal fatigue and flutter.
                I fitted blaster V Force reeds to mine.
                I must be not running my bike hard enough🤣 🤣
                • markus.wM markus.w
                  MadGyverM
                  MadGyverM
                  MadGyver
                  #28
                  @markus-w said in Project DTZr.....a DT125R love story:
                  I agree but I had to do the change by my bad experience with aftermarkets.Also it's easier to find genuine parts than aftermarket locally for me for the DT.
                    MadGyverM
                    MadGyverM
                    MadGyver
                    #29
                    @Calum said in Project DTZr.....a DT125R love story:
                    When I was alone and had this bike in pieces I wanted to put v force.
                    Now I am with family,one kid and second on the way.My pockets are not running that hard.
                    To get the vforce it will cost me around 120 euros,I got this reed cage and 4 pedals (2 installed and 2 for backup)
                    for 70 euros.
                    • T
                      T
                      Tuan Rizkhan
                      Very interesting Project. could you tell me current stage of bike? have checked dyno?
                      • MadGyverM
                        MadGyverM
                        MadGyver
                        Current stage partly disassembled because of electrical problems,checking wiring and everything from the ignition system. Had heavy misfires but not always until it died on me. Dyno is not checked yet.
                        I am recovering from health issue and everything is on hold.
                          @MadGyver
                          Have you got another CDI you can swap out? Or the pick-up from the stator? Could even be side stand related! I love ignition faults! Is it sparking at all now? Give us some deets bud, it’s been so slow I’ve been thinking about buying a newspaper lately! 😛 …
                          • MadGyverM
                            MadGyverM
                            MadGyver
                            #33
                            @SpookDog
                            For 1000km everything worked fine,the last 200km were full of trouble.carb problems(solved),reed problems(solved) and last electrical problems(in progress).
                            CDI ok.
                            Side stand switch was removed from the beginning,electrical connection patched and tested ok.
                            Stator plate not tested after the incident but was tested and repaired before the bike was put together.
                            At first I had weak spark,it was faulty ignition coil,changed with used one,worked ok for 10km's, then heavy misfires and ok only on idle.Then never started again.Removed the ignition coil and tested it with multimeter, out of specs.
                            Order a new from Yamaha,arrived but health issue emerged and now I am on recovery and the bike on hold for recovery also.
                            • MadGyverM
                              MadGyverM
                              MadGyver
                              #34
                              Project's problem update.
                              I installed the new ignition coil,fired right up after 3 months,but the problem remains,above 5-6k misfires and engines shuts off.Now I am troubleshooting the stator coils.
                              I also checked the entire electrical cabling of the DT and cleaned every connection.Didn't find anything but wanted to be calm from that point.
                              • MadGyverM
                                MadGyverM
                                MadGyver
                                #35
                                The custom head gasket I'm using,made by hand and a lot of dremel,it's a mix of the tzr 2RH and the DT's.
                                I didn't test it with one rad but with two works like a charm.
                                  #36
                                  @MadGyver
                                  Do you know which stator you have fitted? There were 3 different types. The first type has 3 separate windings bolted to the backplate, 1 for lights, 1 for ignition and 1 for charging the battery. As far as I know this is the only type that is repairable…
                                  Don’t neglect checking the magnetic pick up and it’s wiring, especially where it exits the casing near the sprocket…
                                  Though from your findings it sounds like the ignition part of the stator is off…
                                    @MadGyver
                                    MadGyverM
                                    MadGyverM
                                    MadGyver
                                    @SpookDog
                                    Yes I know,it's the repairable one,3NC stamp.I order a used in excellent condition from a trading site for vehicles and parts.I spoke with the guy that sells,it had 3,I choose from a photo the one that looked almost new,he told me that is from a low km's DT,it has the 3MB stamp but they are identical.
                                    I checked the parts catalog from various models,the years I want have same codes.
                                      @SpookDog
                                      #38
                                      @MadGyver
                                      You got the whole stator coming to you? It’s a lot easier than soldering in a new winding/coil I imagine!
                                      I’m guessing yours is putting out erratic voltage/ampage. Have you looked for dry solder on the ignition winding?…
                                      Could you see anything hinky with the one fitted? I had a dud lighting coil that only had slight black discolouration to the varnish, but was totally fubar…
                                      PS how did you check the CDI?
                                        @MadGyver
                                        MadGyverM
                                        MadGyverM
                                        MadGyver
                                        #39
                                        @SpookDog
                                        It's the same difficulty for me,replace coil or the whole stator,it needs to come off in both situations.
                                        When restomod the bike I had repaired and checked everything electrical and was in specs by the manual.
                                        Every connection was cleaned or re-soldered.
                                        There is a possibility that source coil/pulser on stator didn't handle the 13000 rpm 😊 some times after the run in first 1000km i did.
                                        CDI checked for short circuit or infinite resistance only.
                                        I am searching for the ohm specs that should have compared with the readings taken,if found will be posted here.
                                          @SpookDog
                                          @MadGyver
                                          I know that the condensers in the CDI (condenser discharge ignition) can go bad, and be fixed. That’s above my pay grade tho 😉
