  3. Wheels
  4. DTR125X Wheel Hubs
DTR125X Wheel Hubs
4 Posts 3 Posters 976 Views
  • BluestoesonnoseB Offline
    Bluestoesonnose
    Hi,
    Does anyone know if the DTR125X wheel hubs are the same as a DT125R and if the brakes etc are interchangeable?
    Cheers
    2002 DT125R
    Glynn123G 1 Reply Last reply
      Hi,
      Cheers
      Glynn123G Offline
      Glynn123G Offline
      Glynn123
      @Bluestoesonnose front hub is different, rear is the same. The dtx front hub has the bigger disc mounting holes and the left side spacer is different if I remember right.
      BluestoesonnoseB 1 Reply Last reply
      • Glynn123G Glynn123
        Bluestoesonnose
        @Glynn123 Cheers, I was hoping to get away with two sets of wheels and one set of brakes
        2002 DT125R
        N 1 Reply Last reply
          @Bluestoesonnose @Glynn123 is correct, front hubs are very different. The only way you could have two sets of wheels and one set of brakes is by swapping the forks from another bike like a KTM. As caliper brackets to convert enduro brakes to larger SM brakes are more plentiful with KTM's. You would also need a custom spacer for the headset and you might have to fanny around with the wheel spacers as well, but they are relatively small problem's to fix if you plan on achieving your goal.
