  4. DTR coil on DTRE
DTR coil on DTRE
2 Posts 2 Posters 639 Views
  • B
    B
    Bananper
    I'm looking for a ignition coil for my dtre, and i found one for sale but it is from an dtr. The part numbers are not the same but does anyone know if it would fit and work? Or do you have other suggestions on aftermarket ones that works well?
      I run that on my DT RE
      https://www.ebay.co.uk/itm/Racing-Performance-Ignition-Coil-Yamaha-DT-125-RE-2006/152317014956?hash=item2376cd33ac:g:X8gAAOSwcUBYKOsT
      The problem is, the CDI's, generator and stator is different from both models. I wouldn't want to run the wrong coil, generate a weak spark, loss of performance.
