  4. Power valve o rings?
23 Posts 3 Posters 3.5k Views
  • S
    The small oring in the gasket set is for the metal coolant pipe. It goes on the end that mates to the pump. Mysteries solved!...
      Hhmm, yeah it's been such a long time since I've worked on that engine
      • S
        Hey! You werenโ€™t wrong, there is a paper gasket. I was wrong about the oring though. Itโ€™s to big for the coolant pipe๐Ÿ™„
