  4. Power valve o rings?
23 Posts 3 Posters 3.1k Views
    The bushes wear out.
    There were different types of powervalves, not sure how they differed on the bush side of things though.
    • S Offline
      One more question! Do you know what the black oring is for? I’ve got a full gasket set with black oring, but the only black oring I found was squashed into the PV and is obviously not right.
      It’s about 3/4 inch.
      • S Offline
        Sorry, was busy thumb typing on a tiny screen!🤪
        It’s not just the bush, the end cap it fits into also seems small. Plus it’s fixed, doesn’t move...
        I’m guessing that the 3mb was a later servo operated valve? Totally different end cap on that side?...
          @SpookDog the markings on the powervalve are misleading. I can't remember what is on the 3mb barrel. I do know that the two barrels take different valves, but I don't think the codes are representative.
          • NottsbikerN Offline
            NottsbikerN Offline
            Dont do what I did when I was being stupid and try and fit the o-rings onto the power valve itself lol
            They go into the end caps and there is also an orange seal for the pulley end as well
            I also got a black o-ring in my Athena gasket kit from PJME and have no idea where it goes
            Wish it was the thermostat one as I need one but its the wrong size
              Thermostat is paper gasket IIRC. Kellogs Cereal will do.
              • S Offline
                Same as in my gasket set, it’s to small. You need a 33mm one for the thermostat. Get one from eBay. If you don’t have an account someone here will probably order it for you. It’ll be pennies ...
                • S Offline
                  Sorry it’s 27mm Inner Diametre X 2.5 or 3mm Cross Section.
                  Calum, cheers for the info bud, it puts my mind to rest. I always worry more when learning a new engine...
                    NottsbikerN Offline
                    NottsbikerN Offline
                    @Calum there is an o-ring under the thermostat itself with the gasket above that
                    • S Offline
                      The small oring in the gasket set is for the metal coolant pipe. It goes on the end that mates to the pump. Mysteries solved!...
                        Hhmm, yeah it's been such a long time since I've worked on that engine
                        • S Offline
                          Hey! You weren’t wrong, there is a paper gasket. I was wrong about the oring though. It’s to big for the coolant pipe🙄
