  4. Help with wiring, blue wires
5 Posts 3 Posters 1.3k Views
  • D
    dan28
    On the 1989 dtr
    There is a small plug on cdi that has a pale blue wire and a dark blue wire the dark blue appears to go to the clocks?
    Then there is a different blue that goes from the ignition to the switch gear and also branches off into a twin bullet connector
    Can some one explain what these wires do I think one is for the bulbs in the clocks but dont understand why one goes to switch gear
    • Y
      Y
      yannikmeister
      The blue wire connects to the neutral switch lightbulb in the clocks. The skyblue cable connects to the neutral switch, which lies down at the gear lever.
      D 1 Reply Last reply
      • Y yannikmeister
        dan28
        @yannikmeister
        Thank you
        Does the other blue go from. The ignition an to the 3 pin plug on the switch gear and also branch off to the 2 pin bullet to feed the clock bulbs
        Even though this wire is the same colour as neutral wire the one from the ignition doesn't meet with the other that goes to neutral light does it
        • Y
          Y
          yannikmeister
          Im sorry for the late answer. Im from germany and not the best in english. Could you explain it differently what you mean?
          • Y yannikmeister
            @yannikmeister Fair play, I mean I am English and even I glossed over reading that 🤣 so you are doing well regardless
