Needle jet
@declan thanks! Bit Will that fit My 2005 dt? Since the earlier ones uses a different carb and needle, How can i make sure this works for mine? It doesnt specify model year anywhere
@Dexter45 they use the same carb providing yours is stock the jets provided may be different all the other stuff should be identical also it specifically says it fits the RE and X models
