  4. dt 125r no ypvs unit advice needed
5 Posts 3 Posters 922 Views
  • S Offline
    savio
    hi there i have a 1989 dt125r that im rebuilding and it is missing the ypvs motor unit and i searched everywhere for one they are pretty expensive. i want know if it can be tuned to run great without the ypvs or an alternative method for my problem as ive seen on youtube arduino ypvs control anyone??
    • S savio
      @savio
      Early DTR125 come with power valve pinned into place. I spent £180 all in for my servo, bush, pulley, pulley body, cover, new cables & rubber servo cover. They can be found cheaper but you have to wait and look around. Do Not get conned into buying a 5 wire servo!! I almost had it done to me advertised falsely. You need the 3 wire servo...
      Nothing else will compare to having it fitted. You have the full power and the low end usability of an enduro. When my bike was pinned open you had to rev the balls off it and slip the clutch just to pull away...
      • NottsbikerN Offline
        NottsbikerN Offline
        It wont bring in lots more servo motors to choose from but the early TDR125 model code 3SH also uses the same 3 wire motor
        Belgarda TDR's were primarily sold in Italy, France and Germany so have a look at those ebay sites as well as the UK one
        • NottsbikerN Nottsbiker
          @nottsbiker
          That’s actually really good to know!
          The bloke I got my setup off of said he trolled the European markets for them, but it was starting to dry up last summer. I Don’t know if true or just hiking up the price. The only ‘kits’ I’ve seen on fleabay lately have been 5 wire servos though...
            NottsbikerN Offline
            I bought one last year for my TDR project as it strangely didn't have one when I got it and from memory it was around £45 from ebay UK which I thought was reasonable
