  3. Frame gaurds
Frame gaurds
frame gaurds
8 Posts 3 Posters 1.1k Views
  • rking7888R Offline
    rking7888R Offline
    rking7888
    Hi guys, looking to fit some frame guards on the dt as im sick of boot rub, anyone had luck fitting early yz ones? If so what years fit, if not any ideas what might fit on there?
    • rking7888R rking7888
      @rking7888 DT200R WR I believe.
        NottsbikerN Offline
        NottsbikerN Offline
        @calum said in Frame gaurds:
        Dont think so as the DT-WR frame is heavily based on the 1989 YZ125/250 frame so quite different to the DT-R one
        • NottsbikerN Nottsbiker
          @nottsbiker Yes, I'm getting the name mixed up with just the DT200R.
          That bike, which is just the DT 200 R
            NottsbikerN Offline
            NottsbikerN Offline
            @calum No problem - I've got a 200WR and TDR125 frame side by side here for comparison so can tell quite quickly as the TDR is 99% DT-R anyways 😉
            • NottsbikerN Offline
              NottsbikerN Offline
              https://www.ebay.co.uk/itm/143324077437?hash=item215ec7dd7d:g:rpMAAOSwvfFdJDQ9
              They were made officially for the 125RE as an accessory by Yamaha but I've not been able to find any left
                rking7888R Offline
                rking7888
                If it's that based on early yz frames do you think that's a possibility? There's a couple of reasonable ufo sets on eBay for 91-92 and 93-95 yz 125/250 , mine spends a lot its time on trails n in woods and I'm fed up with the boot rub and trying to match paint lol.
                  NottsbikerN Offline
                  NottsbikerN Offline
                  @rking7888 not sure tbh as they are different so no idea how close they are for this type of fit
                  You could always make some yourself from some 3mm (or similar) aluminium sheet and attach to the rear brake MC bolts
