  3. DTRE
  4. Dripping oil from the silencer
11 Posts 4 Posters 3.3k Views
  • S
    Skunkno1
    Hi , does anyone else have the problem of oil dripping from the silencer ? Need some help please ,
    Everything Is as it should be , oil pump set correct , engine all good , carb is standard except a 220 main jet ,
    After market exhaust on ,
    It’s at dt re 05
    MadGyverM 1 Reply Last reply
      @skunkno1 pretty normal for a two stroke I don't know why you are worried.
      But yeah could be a whole host of things. Simplest is that the grade of oil you are using is too high. It says on the bottle what ratio to mix the oil to.
      S S 2 Replies Last reply
        Standard tailpipe even has a drain plug built in at the lowest point to drain ‘splurge’. My pipe looks like the Exxon Valdez did a dump on it ☠️
        That being said, rich mixture is the worst in my experience...
        • S Skunkno1
          It’s at dt re 05
          MadGyverM
          MadGyverM
          MadGyver
          @skunkno1 Are you driving with low rpm all the time and for short rides?
          • MadGyverM MadGyver
            Skunkno1
            @madgyver not all the time maybe 50/50, seems to drip more when I rag it
              Skunkno1
              @calum I’m not to worried about it , just wouldn’t mind a clean silencer for a change , and want to know why it’s doing it ,
              I’m using castrol oil,
              • S Skunkno1
                @skunkno1 It's obviously getting too much oil. Saying "I'm using castrol oil" isn't very helpful.
                What is the specific oil you are using?
                • Castrol POWER1
                • Castrol POWER1 Racing 2T
                • Castrol POWER1 Scooter 2T
                • Castrol POWER1 XR 77
                • Castrol POWER1 A747
                • Castrol.Garden Two Stroke 'Oneshot' Oil
                • CASTROL Castrol Power 1 R40
                The list goes on and on.
                Yes, two strokes are oily. You can fine tune the pump but you need to be specific about the oil you are providing it and the ratios you're mixing into it.
                My recommendation would be, if you're not sure, then just leave it alone.
                  • Castrol POWER1
                  Skunkno1
                  @calum it’s power 1 racing castrol , what you saying then back the oil pump off slitley ?
                  • S Skunkno1
                    @skunkno1 I should have asked, are you racing this engine? If not then why are you using the "Racing" oils. Racing an engine is completely different to commuting an engine. Since it's going to spend the majority of the time in wide open throttle. Also most race bikes are pre-mix, although the data sheet says it's good for autolube systems.
                    I'd say, you're using too high grade an oil for the application. Either, back off the oil pump slightly (which unless you know what you're doing don't) or use a more suitable oil which is predominantly used in the mid RPM range.
                    Personally, I wouldn't worry about it. As it sounds to me like you don't fully quite understand the intricacies of the systems to go messing with the oil pump/ratios.
                    Easiest solution would be to use a lower grade oil more suited to your application.
                      Skunkno1
                      @calum thanks for the info , I know exactly how to adjust the oil pump and I know where it should be set , so messing with it’s not a problem ,
                      And yes just commuting really with the bike so not WOT all the time ,
                      What oil would you suggest I use ? Something with a lower flash point ?
                      What about that castrol clean burn semi synthetic oil?
                      Currently using fully synthetic
                      Cheers
                      • S Skunkno1
                        Cheers
                        @skunkno1 I am not going to comment. I run Silkolene Comp 2 Plus and have the same issue 🤣 But I'm not bothered by it.
