  4. Bigger Radiator?
Bigger Radiator?
13 Posts 6 Posters 2.8k Views
  • HOTSHOT IIIH
    HOTSHOT IIIH
    Looking at fitting an Athena 170 kit and/or some tuning work and IMO the stock radiator could be a limitation as the DT200R had twin rads (my temp guage fairly soon goes above 1/2 during hard off-road riding but is fine on the road). Someone in China produces one for the DTR but it's over £100.
    Did some digging on the web and this company in the UK (MXPUK) makes rads for lots of late model MX bikes. Most of their single rads are about £40-£75. I asked the question on their eBay shop and received an encouraging response 😎
    https://www.ebay.co.uk/str/motocrosspartsuk
    Who would be up for one of these if they went ahead and produced a batch for the DTR? Decent stock radiators are getting harder to find so even for the stock bike a brand new, better-than-stock radiator would be a good option. Comment below!
    CalumC Stevie WonderS M 3 Replies Last reply
    • HOTSHOT IIIH HOTSHOT III
      @HOTSHOT-III I'm running DT230 lanza radiators with thermostat removed to good success. Temperature rises to 70 degress centrigrade when on load up a steep hill, otherwise sits at 60 degrees.
      With thermostat I was hitting over 100 - 110 degrees.
        HOTSHOT IIIH
        HOTSHOT IIIH
        @Calum Lanza or DT200R/WR200 rads are a possibility as long as I can find somewhere to put 2T oil.
        Perhaps a later DTRe oil tank and coolant expansion tank?
        CalumC MadGyverM 2 Replies Last reply
          @HOTSHOT-III premix 🤣 🤣
          Yes, I had to fabricate up some brackets for relays and what not.
            Stevie WonderS
            Stevie WonderS
            Stevie Wonder
            @HOTSHOT-III
            Decent quality parts in general are getting rarer and more so even costlier. I’d be only to happy to see and support a British company produce aftermarket parts especially if they provide the option to get twin rads so I don’t have to pay £££’s for 2nd hand bits from Greece etc
              M
              M
              mhbikesnbits
              @HOTSHOT-III keep me updated if you don’t mind in response from the shop, I’m going to be running twin rads from the 200r / or either buy a set from another bike in aluminium and modify the brackets to suit the new radiator how ever if this company can produce these radiators then I’d be very Intrested in getting a original set remade
                MadGyverM
                MadGyverM
                MadGyver
                @HOTSHOT-III said in Bigger Radiator?:
                I've thought everything you say,the easier and low cost way,is DT200R right rad and going premix,left rad you keep yours,you will just have caps on both sides. The oil tank from the later DT's is good option but you need to change the side panels If you have an early DT. For the DT200R right rad you need only to remove a small bracket from the oil tank frame and fits like a glove.
                Temp's running here in Greece is 65-70c in cruising and 95-100c in mountain trails and very hard use on low speeds, with thermostat in place.
                CalumC Stevie WonderS 2 Replies Last reply
                • MadGyverM MadGyver
                  @MadGyver something isn't right with my bike then as with the rad I was getting that temp in the UK during the winter 🤣 it wasn't a faulty thermostat either as i tested that and it works a charm.
                  Regardless, it's running like a dream now anyhow.
                  MadGyverM 1 Reply Last reply
                    Stevie WonderS
                    Stevie WonderS
                    Stevie Wonder
                    @MadGyver useful information, I was gonna purchase full 200r rad setup, brackets, rads, pipes etc the lot so that’s just saved me a pretty penny
                    What’s that reading in regards to position on the temp gauge?
                      MadGyverM
                      MadGyverM
                      MadGyver
                      At what temp your thermostat start's to open?My at 60 and is full open at 80,I don't remember if its a DT125 or from a TZR.
                      Also the head gasket of the kit is has passages for a single rad,I made a custom one that fits the dual rads.
                      @Stevie-Wonder
                      The bottom metal pipe that connects the 2 rads can be modded to become a DT200R.Generic rad hoses from cars can be used.
                      My temp is from a Trailtech VapoX and the sensor is modded and installed in the place that goes the factory one.
                        @Stevie-Wonder
                        @MadGyver sounds like a very similar setup to me.
                        As I recall, the thermostat opened at 80,but I would have to double check.
                        • HOTSHOT IIIH
                          HOTSHOT IIIH
                          Thanks for all the responses guys, I've been corresponding more with the company as you can see! They've proposed doing a CAD drawing of the original rad and working from there, they make radiators for lots of late model MX bikes so they seem to know what they're doing.
                          As you can see my favoured direction is a deeper-than-stock single rad to retain the autolube tank on the 125 (this would also allow retention of the tubular steel radiator guard which most MX bikes don't have) but if they can do this there's no reason why they can't make some DT200R/Lanza sets as well for those who want to go the twin rad route.
                          • B
                            B
                            BEng1968
                            Did you get anywhere with the bigger single radiator?
