  4. Ignition key replacment
54 Posts 4 Posters 8.9k Views
    @erion Key? Or ignition barrel.
    My bike was stolen in 2010 and I replaced the ignition barrel with a Wemoto one. It's not bad, but it isn't great either. About a year later the whole ignition assembly crumbled in my hand and I've had to hand solder all new cables onto it.
    E Offline
    E Offline
    erion
    @Calum no the key thing wich you turn the bike kn and off
      E Offline
      E Offline
      erion
      @Calum how do i post videos and pics here ??
        E Offline
        E Offline
        erion
        @Calum https://imgur.com/a/sTDj42S this is the key i replaced
        • E erion
          @erion
          Yeah, that’s a cheap shit ignition barrel and key! It could well be your problem…
          Try drawing the carb, just to make sure the bowl is filling with petrol…
          Did you put fresh petrol in?…
            @SpookDog The thing about the ignition barrel, is it's literally just a switch with no circuitry so it shouldn't matter too much. It doesn't look the best mind you.
            The problem is @erion We're trying to remotely diagnose a bike with little to no information. Only you know what modifications your bike has and we're really making wild guess based off the little information that you have presented us with.
            What we could end up doing, is focusing on the ignition switch, as it's the only thing you've really mentioned, and this could be a red heron. Ultimately wasting your time and ours...
            E 1 Reply Last reply
              E Offline
              E Offline
              erion
              @Calum im sorry if im wasting your time , but as far as i know the bike doesn't have any modifications its bone stock and im just trying to get it start up again so i was looking for some advice on where to look at first or what the problem could be related to
              • E erion
                E Offline
                E Offline
                erion
                @erion if its ignition problem where should i start checking
                  If you're unsure, then the first thing to do is to locate an original OEM ignition barrel and put it back to how it's supposed to be. Rather than taping up wires and probably not making a good connection. Then at least we can start to rule out the ignition switch as being the fault cause.
                    E Offline
                    E Offline
                    erion
                    wrote on last edited by erion
                    #49
                    @Calum i'll check that , btw here is a video of what's happening https://imgur.com/a/bT64mhz
                    • E erion
                      @erion
                      Check the spark plug while someone else kicks it over, if it’s intermittent or weak; change the ignition barrel (I would put a genuine one in anyways). If it’s good and strong; strip and clean the carb again properly, remove the jets and check/clean them. Remove the main jet tube and clean the outside and inside and small holes in the sides. Remove and check the choke plunger. While it’s apart spray through all the holes with carb cleaner or even just air.
                      Drain the tank and use fresh petrol and 2stroke oil!…
                      It’s really easy to miss something on a carb when you first start doing them. Practice and (learning by!) many mistakes make perfect (in my case 😛)
                      Good luck! 👍 …
                      S E 2 Replies Last reply
                        @erion
                        Good luck! 👍 …
                        Just watched your vid. Sounds like it’s hunting for fuel almost straight away. Drain your carb bowl (with tap turned off!) from the tube at the bottom and see how much petrol your carbs bowl is holding. I’m guessing it’s not much at all. If there’s bugger all fuel check the needle valve on the floats…
                          @erion
                          Good luck! 👍 …
                          E Offline
                          E Offline
                          erion
                          @SpookDog checked the spark plug the gap was big so we closed it a bit i kicked the bike while my dad checked for the spark he said that there is a good spark but i will check it myself one more time , it may be the carb not getting enough fuel
                          • E erion
                            E Offline
                            E Offline
                            erion
                            @erion or maybe not at all
                              E Offline
                              E Offline
                              erion
                              @SpookDog this might be it i'll have a llok at it bc after that start the bike won't start again like that if i dont let i rest some minutes
