  4. Runs with choke
Runs with choke
76 Posts 6 Posters 17.4k Views
  • OllieDTRO OllieDTR
    @SpookDog
    I’ll take the gasket off today mate, I’ve had a couple dts and mx bike I’ve always done rebuilds on but this one seems to be testing me…
    I’m currently running 240 main
    25 pilot
    Went for a ride on choke then turn choke off when moving goes for Abit then bogs when let off and try to use throttle again just bogs but flick the choke back up and runs again
    Am I thinking it’s lean?
    I’m off to get some brake cleaner in a minute and going to test for leaks again
    #41
    @OllieDTR
    It’s definitely lean. It’s just where the fux it’s taking unmetered air at? The power jet pipe is connected, yeah?
    OllieDTRO 1 Reply Last reply
      @OllieDTR
      OllieDTRO Offline
      OllieDTRO Offline
      OllieDTR
      @SpookDog
      Powerjet is connected, I’ve blasted brake cleaner around everywhere and no change in revs, I’m going to completely take the carb apart everything and clean and check everything
        @SpookDog
        @OllieDTR
        I had to ask, I honestly don’t think that you’re as big an idiot as me 🙂 I just don’t understand where an air leak big enough that changing the jetting as you have, has made no difference, can be…
        Again, sorry, I have to ask! You are spraying and checking while the choke is off? When I sprayed even a tiny bit near where the leak was my engine stopped ‘hunting’ and settled down.
        Yours will tick over without choke yes? But be all ‘fast & twangy’?
        There are only so many places air can enter unmetered
          @OllieDTR
          OllieDTRO Offline
          OllieDTRO Offline
          OllieDTR
          @SpookDog
          Fixed it!!!
          So airscrew didn’t have a o ring so put one in.
          Also when I was checking air leaks nothing, so I thought I’d take carb out and check all rubbers, where the jubliee clip tightens up onto the carb on inlet there was a hairline crack under the clip which I only saw when I flexed it about. so put the carb back on and sprayed like 2mm away from the place I saw the crack and sure thing revved up. So that’s why I didn’t rev before when I sprayed because I had to be really really close to it!
          After all that 😅 I’m glad though crazy how a tiny tiny little crack can do that but where it was hidden under the clip it didn’t pick up the brake cleaner until really close.
          Thank you everyone been a couple of stressful days but that’s a win and learn something on the way
          3
            @SpookDog
            Fixed it!!!
            @OllieDTR Cool you've fixed it 👍 👍 Here you go bud, DTRe 1D01-1D03 (2004-onwards) wiring diagram as discussed:
            I'd still try those washers above and below the carb needle E-clip, stopping that moving up and down too much will be no bad thing. And here's a pic of my airbox when I sealed it up, this is why I like to take them out to do this so the part you've glued can sit on the bench horizontally while the glue goes off. While you've got the Seal-All out you can also replace the foam on the back of the filter element holder where it slides into the airbox as this is another thing "previous owners" miss, it rots out providing another route for dirt to get in. 5mm air filter foam is pretty cheap on eBay etc.
            https://www.repairingproducts.co.uk/product/seal-all-gas-oil-resistant-adhesive/
              @SpookDog
              Fixed it!!!
              @OllieDTR
              Fuxin sweet! All you have to do now is make sure you got the right jetting for the carb! 😛
              Have you got another rubber inlet? I can probably flog you one if needed. I went through a spell of snapping them up after I had my ‘cracking up problems’…
              I did ‘inject’ silicone sealant into the split and around it for a temp fix. Nothing beats a good seal though…
                @OllieDTR
                OllieDTRO Offline
                OllieDTRO Offline
                OllieDTR
                @SpookDog
                Result ay mate! Was on the phone with @HOTSHOT-III and we was running through some stuff and made me think to double check and check again everything.
                I’ve just picked my spare one up from my mums so will be putting that one on tomorrow.
                As regards of jetting I’ve got
                4th clip on needle
                240 main
                .25 pilot
                I’m sure that’s correct for my year as it’s an DTRE engine.
                I just wasn’t sure if I needed to upjet at all as I’ve got dep, Boyseen dual stage reeds and 1mm oversize re bore?
                I will do a plug chop when it’s all running properly and go from there
                • OllieDTRO Offline
                  OllieDTRO Offline
                  OllieDTR
                  This post is deleted!
                    Sounds like it's running lean on fuel then. There is a good guide on here to jetting. Sounds like you've got either two options.
                    Put it back to standard, or jet to suit. I'd just do the latter. A bit of playing around, but you'll get it I'm sure.
                    • OllieDTRO Offline
                      OllieDTRO Offline
                      OllieDTR
                      @SpookDog @HOTSHOT-III
                      I feel like a right idiot…
                      So the main problem was the split in the inlet rubber got new one on. But when I was changing the jets I had a jet that came in the carb already and that 20 pilot from mikuni I put it next to a .20 pilot I had from my new jets and the new jet holes was tiny compared to this one, to get the same size holes from my new jets compared to this 20 I had would be like a 35…
                      Never buy jets from eBay that’s a Chinese seller I guess
                      So anyways my mates got a dt so I rang him up and borrowed a 25 pilot and sure thing it ran the sweetest ever!! So now I need to order a 25 pilot from a good company also will probably get a 240 main jet aswell while I’m at it
                        #51
                        @OllieDTR
                        Bud! I’ve done the fleabay SHITTY jet thing myself. Don’t beat yourself up, it’s all a learning curve 🙂 …
                        I got a good aftermarket .25 jet from
                        Sportaxracing. The difference it made to my bike was unbelievable. Starts first kick, ticks over and revs up crisp and clean. It’s where I’d go…
                        I’ve also bought ‘EBC’ jets that were shite, because getting a Mikuni genuine.25 is impossible in the UK. I don’t know if a genuine 240 is possible either…
                        I’m happy for you that it’s running sweet! 😇
                          @OllieDTR
                          OllieDTRO Offline
                          OllieDTRO Offline
                          OllieDTR
                          @SpookDog
                          I was annoyed but pleased at the same time I finally narrowed it down mate!
                          What do you think of these?
                          https://jetsplus.co.uk/product/mikuni-pilot-jet-vm22-210-ax100-en-tzr-tm-2-stroke-4-stroke-10-65/
                            @SpookDog
                            @OllieDTR Looks like a good website to me but TBH I've never bought a Mikuni pilot jet so I wouldn't know how to measure them to ensure they're genuine. I think there's a set of gauges you can buy which are just labelled bits of wire the correct diameter.
                            Mikuni main jets you can get from PJME so it might be worth calling them and asking about the pilots, also try Allens Performance in the UK or Mikunioz.com (things posted from Australia arrive surprisingly quickly).
                            https://mikunioz.com/?v=13b249c5dfa9
                            https://www.allensperformance.co.uk/
                            And I'd take a look at Yamaha France parts lookup, get the part numbers of the jets from a late model DTRe and then Google for these because someone somewhere might have a NOS one and if it's in a sealed bag with a Yamaha part number it's bound to be genuine.
                            Yamaha France is a very good resource generally; very accurate and they seem to have info for any Yamaha product, not just those sold in France and on a PC you can just hit Translate. As an experiment I keyed in the VIN number for my original 1990 white/red UK (i.e restricted to 12bhp via no YPVS servo and PV pinned closed) DTR I owned in 1992 and it showed the PV end cap on the barrel instead of the YPVS pulley, cables and servo. Obviously it made no reference to myself and several other teenage malcontents accidentaly on purpose reassembling these components by the side of the road to alter this about an hour after I bought the bike...
                            https://www.yamaha-motor.eu/fr/fr/service-maintenance/parts-catalogue/
                            • HOTSHOT IIIH HOTSHOT III
                              OllieDTRO Offline
                              OllieDTRO Offline
                              OllieDTR
                              @HOTSHOT-III
                              Thank you for all that info bud if doesn’t go un missed!
                              So today I’m going to look at my slide to see what number it has on it, just looking at the emulsion tube needle etc it’s definitely the higher jetting rather than the dtre 210, 17.5
                              As yesterday I tried the 20 pilot that came in the carb and had to have the airscrew right in so definitely needs upjet so I can have it 1 to 1.5 turns out so with the 17.5 the standard DTRE engine has that’ll be to low, maybe it’s because it’s got some “performance mods” on to the bike bike now I don’t know, I’ve ordered from that jets place now looks like one of the better sites and got good reviews, I’ve ordered 210 main, 220 main, and 240,
                              22.5 pilot, 25 pilot and 27.5 pilot just incase I need to go to 27.5 not sure why I would but always good to have incase,
                              I paid £8 before for them other jets that should ring alarm bells as I got like 20 jets for that price😂 and now I’m paying £5 a jet
                              Ready for the road soon 🤞🏻
                              I did order a horn for the bike from AliExpress and it cost me 40p with free shipping and it arrived in 8 days😁 it works like a horn and can’t complain for 40p 😂
                                Yeah, if you're going to use aftermarket jets then DON'T JET TO STANDARD! Jet to suit!
                                It's fine to have knock off jets, provided your entire collection is knock off.
                                I just buy genuine jets and stick to genuine.
                                240 genuine may be 210 or 260 knock off. So to say "It's stock jetting" but using aftermarket jets would leave us scratching our heads as to why it isn't working. Potentially leading us to misadvise and cost more money in the long run.
                                I don't have Mikunis in any of my bikes, they are all Dellortos and Eurocarb seems to have me covered on that. Dellortos were also used on the Belgarda engines as well as the Aprilia RS 125s and many Italian bikes. Common scene in the Vespa/Lambretta world and therefore abundance of parts available.
                                Not sure why you're having trouble with Mikunis...
                                  #56
                                  He bought the bike with the wrong jets fitted, You can’t get a .25 Mikuni genuine pilot jet in the UK for love nor money 🙂
                                  I got a .25 pilot from sportaxracing and i know the bikes been running sweet since. It’s unmarked but runs perfectly. I really couldn’t comment on the others…
                                  Only way to tell a genuine Mikuni jet is that they have a tiny ‘square in another squares corner’ stamped into them…
                                  • OllieDTRO Offline
                                    OllieDTRO Offline
                                    OllieDTR
                                    So jets arrived today put 25 pilot in and runs a lot better but still hangs for couple seconds before idles good again. Air screw all the way in so needs bigger, I’ve ordered 27.5 and 30 pilot
                                    Strange how big it is but all bikes different I guess
                                    Mod list
                                    Boyseen dual stage reeds with rev plate
                                    Dep downpipe and end can
                                      Mod list
                                      @OllieDTR to be fair, all my bikes do that to some degree. The revs hang at 2000 rpm before dropping to 1100. But I assumed it was due to lack of oil pump 😂
                                      • OllieDTRO Offline
                                        OllieDTRO Offline
                                        OllieDTR
                                        The float height is definitely around 16mm guys? Seen everywhere It’s 20 to 21mm then some places 16mm TM28ss
                                          @OllieDTR
                                          15~16mm
                                          The 21 is the setting for the 26mm round slide Mikuni fitted to early bikes…
                                          Have you fitted the 240 main? There’s no way you should need a bigger jet than 25. Needle 1 groove up from the bottom. Airscrew 1&1/4 turns out…
